Question about Maytag Washing Machines
I have a maytag washing machine that recently stop working. The tub fills up with water but the dial won't rotate and won't go through the wash cycle
Hi there crporter3,
dial won't rotate...jamed or stuck. needs new wash rotary switch.
Posted on Jul 05, 2008
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
MAYTAG NEPTUNE TOP LOAD DOES NOT FILL TUB WITH WATER HEAR NOISE BUT NO WATER AND STOPS AND 24 MIN QUICK WASH CYCLE, NOT SURE WHERE TO START.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL starts, fills with water a few sec then clicks loudly a few times and then stops, a few sec later it repeats this, then stops for good. Tried unplugging and restarting, but same thing...
Any error codes?
Do you want to troubleshoot? If so here is the Service Manual.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
I would start by removing the front cover of the machine follow all safety warnings in the Service Manual.
Follow the first few steps in my Clutch Fix post to remove the front cover.
Then let me know if during the water fill cycle the machine rotates the wash basket CCW in a slow spin during the water fill cycle before the machine stops and we will go from there. Give me all the detail you see with the front cover off I need to know if the wash basket is rotating CCW during the washer fill cycle.
You can lift the washer top up a slight amount to observe the slow CCW spin of the wash basket. I’m checking that the outer tub bearings are not seized……Rich
To pump out the excess tub water with this process;
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
This process is documented in the Service Manual. I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Jun 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
