Question about Sony Cyber-shot DSC-S700 Digital Camera
Lens jammed how do i remove the lens motor so i can re-align the gears. the camera was dropped and partly disloged the retractable lens. I have removed the lens unit from the housing and think i have a fair idea as to how to reseat the mechanism once I get the motor off retractable lens isn't working
  • Anonymous Jul 15, 2008
    I have the same problem, the lens is not work normally. Somebody helpme?
The lens needs to be removed.  The camera case can be taken apart by using a small philips screw driver and a small flat head. Take the batteries out. Have a nice flat space to lay the screws out.  Pry out the little chrome piece with the UL sticker on it. (Carefully use the flat head). Start somewhere you will remember and begin to remove the screws going clockwise around the camera.  There is a screw under the rubber flap of the "3X" chrome cover.  The top of that must be pryed out and lifted up to remove. Take the back cover off. Lift out the top of the LCD screen and remove the 4 screws that hold it in. Start a new row of removed screws. The LCD ribbon can be removed by popping the white plastic clasp up. Next remove the menu pad ribbon from the board by lightly tugging on it. You should be able to remove the front cover by lifting it up to unhook it from the top power button strip. There are 2 screws that hold the top power strip in place. There is also a plastic hook on the front side. There are 6 screws holdong the board to the frame. A different size screw is located underneath the power strip ribbon. Loosen the 2 screws holding the flash.  THe white ribbon will be the flash ribbon and the gold one next to it will be the lens ribbon. NOTICE the lens ribbon must pass under the flash.  The side with the lens will have a small board that pushes into the main board.  To seperate it, gently pry it apart with a small flathead. There is a hidden screw for the board at the top where the end of the battery compartment. It needs to be removed before the board will come out. Once the board is out, there are three screws holding the lens in the case (they are black screws, not the chrome ones)  Once they are removed, the lense will fall out. There are 3 black screws holding the largest motor on the lens.  They are above the text "Sony Lens" remove those and the gears of the lense will be able to move freely. Twist the base to get the lense unstuck.
Posted on Feb 04, 2009
2 Suggested Answers
  • 48 Answers
SOURCE: lens jammed
go to a **** and get a bj that might help
Posted on Jun 25, 2008
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
My daughter just dropped her camera, now the silver part/zoom lens wont go back in and its says, lens error 211. i tried removing the batteries and putting them back in but nothing has changed. what do i...
The lens has been damaged, or knocked out of alignment. There is a tiny motor that extends and retracts the lens, you will need to take it to a camera technician to assess whether it can be repaired or replaced.
Jan 17, 2011 | Kodak Easyshare C182 12MP Digital Camera
My kodak c195 keeps saying lens obstructed and the lens won't go down
There is a tiny motor that extends and retracts the lens, sometimes it will jam because part of the gear breaks causing it to malfunction, I would imagine the cost to repair will be high
Jan 10, 2011 | Kodak C195 Digital Camera
Nikon Coolpix camera lens can not go back, how to fix it, thanks
Camera lens are made retractable by means of mechanical components such as gears and motors. If it won't retract, there is a big chance that the gears were misaligned or jammed. I suggest not to attempt any tear down or disassembly as it might damage the lens. You can visit your local camera shop and have it fixed.
Jun 13, 2010 | Nikon Coolpix L11 Digital Camera
Lens is stuck and will not retract
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Dec 13, 2009 | Fuji FinePix A820 Digital Camera
I dropped my camera and the lens won't retract. The screen reads lens error restart camera. Even though I have removed the battery to restart the camera, it won't correct its self. The lens stays out.
When you reset the camera you should be able to hear the gears of the camera lens turning. The problem is that the lens is out of alignment so the lens can't slide back in. As the gears are turning, straighten out the lens (you might have to try forcing it in different directions if it's not obvious which way the lens is bent) and it should slide back in. You obviously want to be gentle enough to not break it, but sometimes you have to use a little bit of force based on the severity of the drop. You also might need to try a few times since the gears will only run for so long before stopping. I have fixed a few cameras this way but if the lens is bent too far out of alignment you'll have to get it profesionally fixed.
Apr 27, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens Stuck open on Mz67 hp camera Error code Mz60-022
Was this stuck fully open or was the lens partially opened, or was the lens jammed?
The lens can be removed and replaced with another lens from another non-functioning camera (See ebay). The lens component can also be dissembled. Putting the lens back together is tricky because the parts have to be aligned just right for the lens to work. If working with a Jammed lens, extra care has to be considered not to break any of the moving plastic parts of the lens or that part (if not entire lens) is junk.
With the motor detached from the lens, the lens should extend and retract freely. Use this to test the lens when you dissemble the camera. Be careful of the flash board.
Mar 15, 2009 | HP Photosmart MZ67 Digital Camera
Lens jammed
Jun 25, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
237 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
