Question about Fisher and Paykel GWL11 Top Load Washer
My fisher paykel eco smart is GWL11 not GWL15
My washer stop working with 3 leds stay lit up... it wont turn off 3 leds are wash 3rd and 4th and spin led My GWL11 at first would not spin out. Now the third wash, rinse, and spin lights are on, and it beeps.
  • 3 more comments
  • pete g Jun 28, 2008
    My Fisher Paykel smart drive washer stoped intermiditently for a time and now it wont go at all. It would stop at different parts of the cycle the last time it stop part way through a fill and is still there.I think its a curcit board problem Could you please help, Regaeds Pete.
  • Anonymous Aug 17, 2008
    Our sons were doing laundry when we were out of town.  They called to say that in the middle of the cycle, water and tons of soap were coming out from under the machine.  When they opened up the machine, it full of soap more than water.  We ran a test load of laundry when we got home only putting in a very small amount of soap and a low water level.  During the rinse cycle, it didn't sound as if it was spinning; it then sounded as though it tried to put on the rinse cycle and it then shut off.  After that, water and tons of soap came out from the bottom.  We tried taking the plug out as it had recommended in the book and then reprogramming it, but the cycle never really rinses and there is a very small amount of water just dripping from the hose, and it is not really rinsing the clothes.
    Please send  reply as soon as possible - We have a Eco Smart GWL15 top loader
  • ronaldo35 Feb 08, 2009
    I have fisher and paykel iwl15 washing machine. Half way through the washing cycle it starts beeping, says call a technician. The water won't shut off and it is almost overflowing. I killed power and it then worked for couple weeks. Now it is doing it again. And one time we got an error code 12. I think it's the circuit board. Any ideas?
    And does anyone have the parts for cheap?
    Ron
    402-770-7946
  • Anonymous Mar 18, 2014
    Has lights on the wash, rinse and spin beeps every second
  • Anonymous Mar 28, 2014
    led light does not work but power is their
  • 28 Answers
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Posted on Jul 03, 2008
Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
My washer stops when it is in the draining proses almost when it has draining all water and it wont continue
Hi just read your posting.Now when the machine stops does, it beep and show a series of lights.If it does show lights that are lit then they will be in a row of 8 lights.Starting from left to right which ones are on?Is it the 2nd and 4th or the 5th and 7th ---etc---?Please reply with additional information and I can help you rectify this problem.
Jul 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Power wont go on fisher paykel eco smart GW11
first step is to make sure you do have power to your washing machine.
if you press your power button and you dont get any response,you will find the your electronic have gone.
Its called a power module.
They do have fuses in them.
Jul 31, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Press "end of cycle" for 5 seconds or more to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Fisher and Paykel GWL11 Top Load Washer Logo
1,185 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
