Question about Hunter 22451 The Brookline Brushed Nickel Ceiling Fan
Oh **** I pull the chain to make the fan work so hard that i pulled it off. Here's a pic of the fan with a small hole where the chan was: And here's a pic of the chain: So can anyone give me instructions on how to reconnect the chain?
  • Cory5468
    Cory5468 Jul 20, 2008
    Never mind, I got it now, but can you give me instructions in case it happens again?
ceiling-fans
  • 20 Answers
SOURCE: Pull Chains Replacement
Replacements are available at Home Depot and Lowes. This is a regular 4-wire single-layer switch.
Mark the old wires, so you know which ports they go to in the switch (marked L, 1, 2, and 3) -- then remove the old wires by pressing a paper clip into the hole of each wire while pulling firmly on the wire. Then just push the wires into the new switch, into the marked holes.
I hope this helps! If you have any more questions, please feel free to ask!
Posted on Jun 17, 2008
SOURCE: Driver and instructions to pull pics off camera
I have tried getting the driver from GE but after downloading it, it say this file cannot be opened (the ext. is .bin)
Posted on Oct 05, 2008
TamirMeiri
  • 94 Answers
SOURCE: small memory card stucked inside SD memory card hole
vijju_rasala hello,
Please go to the following address, and insert your model number. There you can find specific instructions on how to open your laptop properly.
http://www-307.ibm.com/pc/support/site.wss/product.do?doctypeind=8&template=%2Fproductselection%2Flandingpages%2FonlinePublicationsLandingPage.vm&sitestyle=lenovo
Posted on Oct 30, 2008
louislevel_2
  • 374 Answers
SOURCE: The switch that controls my fan speed is in the
hi there,
that was a common problem on that fan, the chord chain was stuck on slot groove way to rotary switch inside you ceiling fan,the only way to
repair this to disconnect and pull out the ceiling fan and dismantle the housing whrere the control switch is located, b4fb3a6.jpg upon opening you can see the groove where chord chain was stuck released,possible if you can change the chord w/c is a smooth one so it will never stuck,then reassembly again and put it back, or you can change the control switch by modifying the circuit control and put it on your wall,but this is not easy job you can hire and certified technician to do this,have a good day.don't forget to rate me,thanks a lot.
Posted on Apr 28, 2009
  • 67 Answers
SOURCE: Light pull chain pulled completely out of fan base
yep hardwars store easy one
Posted on Jul 25, 2009
Fan pull chain not working.
The switch needs to be replaced. They are available from hardware stores, or big box stores that sell ceiling fans.
Apr 12, 2015 | Dryers
Why does do I only get one fan speed, and not three on Model 27185?
The light is only a battery indicator light. Check the capacitor in the switchcup. Small, usually black box with wires going to pull chain switch. Also, the fan has to be set on high at the pull chain for the remote to work correctly.
Aug 17, 2014 | Dryers
Pull chain hanup on glass light cover
Take the glass off and see if there is a hole in a small plate below the light sockets. The pull chain should go thru this hole first before the glass. I don't know if this has it or not being that it's a low-end store brand fan.
Jul 28, 2013 | Hampton Bay Ceiling Fan. Hawkins 44 in....
Replaced pull chain switch and lights still won't
As there are only two wires for the light kit I would say you have a bad switch or bad light kit. Send a pic if you can.
Feb 02, 2013 | Dryers
PULL CHAIN FOR LIGHT BROKE AND IS INSIDE THE UNIT. HOW DO I GET THE LIGHT UNIT OFF TO GET TO THE PULL CHAIN UNIT.
"PULL CHAIN FOR LIGHT BROKE AND IS INSIDE THE UNIT. HOW DO I GET THE LIGHT UNIT OFF TO GET TO THE PULL CHAIN UNIT."
My oh my!
I don't know of any shortcuts, and the working position does not make the operation a pleasurable one. Not in Summertime!
The time I had to repair that, I needed to pull the whole fan down. Once the whole fan was down, the rest was easy!
It's easier that it appears, but mark all the wires connected in the box.
There is USUALLY a steel cable attached to the fan assembly and the box, to prevent the thing accidentally falling on someone's head.
If you don't have a helper, taking the blades off may be a good idea, but don't take my word for that. Putting them back on was no picnic.
FYI. If you don't have any bead-chain handy, a suitable lenght of sash cord is probably the best replacement.
May 15, 2011 | Hunter (25417) Ceiling Fan
Can't pull the starter cord, it's very hard to do. Removed spark plug and then the pull cord worked fine. Put the spark plug bvack in and once again the starter pull cord was hard to pull. Seems...
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Echo CS400 18" Chain Saw
I need to reverse direction of fan
mcdevito75 here, Close to the ceiling but still on the fan motor shroud should be another small pull chain switch, this pull chain switch is the fan reverse switch, the switch may also be a toggle switch but I doubt it. Look close to the other pull chain switch for the fan, for the reverse switch.
Jul 26, 2010 | Hampton Bay 24750 Huntington III Ceiling...
I pulled on my ceiling fan pull chain and it came out, do I have to replace the pull chain attachment
Hopefully not.
Can you see a part of the chain stickong out of the fan housing? If so, get a "link" and re-connect the piece that fell off.
You can get a link (or a small chain) at WalMart key-maker or any hardware store (Ace, TrueValue)...
Sep 21, 2009 | Dryers
May 22, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Hunter 22451 The Brookline Brushed Nickel Ceiling Fan Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
