Question about SanDisk Sansa e250 MP3 Player
Error in sandisk e260 mp3 player
My e260 is not getting activated even after running the "firmware e200fw01.00.12.exe" file. and when i tried to format it, its giving the error sayin "LUN0 locked / unlocked" repeatedly.
  • 8,596 Answers
Your player is locked - there is a lock switch on the sign that needs to be disengaged.
Posted on Jul 03, 2008
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
What is the supported file to watch video or photo
  • Photo formats: BMP, JPEG, TIFF, GIF
  • Video Formats: AVI, MPEG4, WMV, QuickTime, MPEG2, ASF
  • Use the Sansa Media Converter to convert videos to a format that the Sansa can display. The Sansa Media Converter can be installed by running the Sansa Firmware Updater. The Sansa Firmware Updater can be found at:
    http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
    Feb 09, 2010 | SanDisk Sansa e260 MP3 Player
    I own a sandisk sansa e260 4.0gb and for some reason my computer is no longer recognising my mp3 player? I am currently running Microsoft 11 on my computer, could this be the problem? My other issue is...
    Having the Sansa e260 and running WMP11, the easiest way for updating the drivers on the computer for connection is to download the
    Sansa Firmware Updater. After the download, start the execute file
    SansaUpdaterInstall.exe . You should be logged onto the computer having administrator rights, allowing you to run this execute file.
    See next link how to use the automatic updater function, method 1 ( and updating manually going to Sansa forums, method 2 ) :
    http://kb.sandisk.com/app/answers/detail/a_id/306
    The error for converting wma files to mp3 is caused by not having the
    valid media usage rights (any more) for the music to get them copied or converted.
    This could be solved by playing or synchronizing the song at least one
    time, before trying to convert. First check next setup in WMP11:
    In the Sync tab select More Options.. , under Privacy look
    for and select the box "Download usage rights automatically when I play or sync a file".
    Main support overview links for the Sansa e200 series:
    http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC8xUDF2cU1Rag%3D%3D/sno/0#e200
    I hope this helps you solving the problems.
    Need more assistance ? Just post a comment.
    Dec 30, 2009 | SanDisk Sansa e260 MP3 Player
    Can't access files on Sansa e260
    I had to install the update on to my labtop and finally it recognized it and updated....
    Download Update if you haven't yet on a flash drive for the labtop definite 2.0 usb port... (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
    Apr 21, 2009 | SanDisk Sansa e260 MP3 Player
    Player will not turn on or charge
    we can solve this problem , only if it still got recongnized by computer.
    if it still try download the firmware and start upgrade it from this link below
    also try to give a good feedback^^
    http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
    Mar 25, 2009 | SanDisk Sansa e260 MP3 Player
    It won't start now!
    Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
    Sep 22, 2007 | SanDisk Sansa e260 MP3 Player
    Getting messgae Not enough space for MusicDB. Please free 6MB
    If it wont connect to the PC, you need to put it into recovery mode and format it with the recovery tool from SanDisk. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
    Sep 14, 2007 | SanDisk Sansa e260 MP3 Player
    Sensa e260
    Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Best of Luck.
    Sep 05, 2007 | SanDisk Sansa e260 MP3 Player
    Freezes up when playing video
    Hey, my sandisk e260 mp3 player does the same exact thing, however i hold the power button for about 30 seconds and then it resets.
    Apr 25, 2007 | SanDisk Sansa e260 MP3 Player
    CAN'T FORMAT
    do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
    Mar 26, 2007 | SanDisk Sansa e260 MP3 Player
    SanDisk Sansa e250 MP3 Player Logo
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
