Question about Apple iPod MA446LL/A MP3 Player
Ipod classic video
I bought the 1/8" plug in for the ipod classic, but it won't play video out. It says I need the apple plug in to work. Can you set the 1/8 inch out to play video?
  • 405 Answers
You need a special 1/8" cord for video output. For example the standard 1/8" cord has 2 black rings on the 1/8 plug, each ring is a channel one for left side and one for right side. You need an 1/8 cable that has 3 rings on the plug, 1 for video, 2 for Left and right audio channels. It dosen't have to be an IPOD brand cable it just needs the 3 black rings.
Good Luck
Posted on Jun 27, 2008
On the ipod 20gb after apple logo comes then bettry logo comes
Reset Click Wheel Ipod (newer ipods including resetting an ipod video)
1. Flip the Hold switch on and off and make sure it ends up no longer on hold.
2. Press and hold the Menu and Select buttons (center Button) until the Apple logo appears (may take 5-11 seconds, and you may need to repeat this step)
If this not work for you try plugging your ipod into computer or wall power
Resetting iPod (with dock connector)
Most problems with iPod can be solved by resetting it.
To reset iPod:
1 Connect iPod to a power outlet using the iPod Power Adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3 Press and hold the Play/Pause and Menu buttons for at least 5 seconds, until the
Apple logo appears.
If Your iPod Won't Turn On or Respond
* Make sure the Hold switch is off.
* If you're using the iPod Remote, make sure the remotes Hold switch is off.
* If that doesn't work, connect iPod to the iPod Power Adapter and connect the
adapter to a working electrical outlet. Your iPod battery may need to be recharged.
Resetting iPod (with out dock connector)
If that doesn't work, your iPod may need to be reset.While the iPod
is connected to power, press and hold the Play and Menu buttons
for at least 5 seconds, until the Apple logo appears.
Mar 03, 2011 | Apple iPod classic MP3 Player
My ipod has a circle red x on it and wont respond
First try resetting the iPod. If this does not work then restore it.
To RESET IPOD: 1 Toggle the Hold switch on and off (slide it to HOLD and then back again). 2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
To RESTORE IPOD To update or restore iPod classic: 1 Make sure you have an Internet connection and have installed the latest version of iTunes from http://www.apple.com/itunes/download/?ipod 2 Connect iPod classic to your computer. 3 In iTunes, select iPod classic in the source list and click the Summary tab. The Version section tells you whether iPod classic is up to date or needs a newer version of the software.
In Restore all data is erased from iPod classic, including songs, videos, files, contacts, photos, calendar information, and any other data. All iPod classic settings are restored to their original state.
Jul 19, 2009 | Apple iPod classic MP3 Player
IPod Classic won't play video with AV Component Cable
I have the exact same problem, having previously tried the component cables. I called tech support who stated that my ipod classic must have some sort of hardware malfunction when otherwise fully functional. I can get sound through the RCA cables, but no video. What gives?
Jul 16, 2009 | Apple Composite A/V Cable for iPod...
Ipod Sound Quality Terrible
Go into settings, EQ, and try out some of the EQ settings.
Jun 03, 2009 | Apple iPod classic MP3 Player
CLICK WHEEL IS NOT RESPONDING
Hi!
Please try resetting the ipod by pressing the center and play button on your ipod until it displays apple logo. Also try restoring it to factory settings by seeing this link from apple---
Restoring apple ipod
Please rate this solution if you find this solution helpful.
Thanks
Rylee
Feb 08, 2009 | Apple iPod classic MP3 Player
I purchased a sonic impact video v55 for my daughter. It will play her audio files from her ipod but not her videos. She gets this error on her ipod: TV out enabled, please connect video accessory
Ok, i found out i do have a 5th generation ipod and i went to the apple store and the problem was i had to set my ipod video settings to TV Out to ON and TV Signal to NTSC then set to widescreen ON and the tech plugged it in and she worked like a charm, hope this helps
Dec 25, 2008 | Sonic Impact Technologies iFusion Video...
How can I play video files stored on my iPod player onto my portable Philips DVD player (it has an iPod dock)
You need a camcorder A/V cable that has a three-plug RCA connection at one end and a three-banded 1/8" plug on the otherad647c1.gif
iPod settings as follows:
TV OUT: ASK
TV SIGNAL: If you live in the U.S., your TV works with the NTSC standard. European countries mostly use PAL.
WWIDESCREEN: Choose your poison here... it all depends on your tv
May 21, 2008 | Apple iPod classic MP3 Player
Jensen VM 9311 iPod Classic
The new ipod will not work with anything other than 2008 alpine products. Apple embedded a chip in the actual cable that tells the ipod that it's ok to pay. What you need is an authentic apple video cable that can only be purchased at the apple store...then hook the inputs up to the video input on the radio.
Mar 28, 2008 | Jensen's VM9312 Car DVD Player
Monster Cable iTV Link to IPOD Classsic 80Gg
Is it also plugged into the TV? Maybe it is expecting to see some signal on the other end.
Jan 20, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod classic
You have to roll back the firmware to 1.0.2 in order to get video its the only thing i have been able to find that works and i have been searching for a long time
Jan 09, 2008 | Pioneer AVIC-D3 Car DVD Player
Apple iPod MA446LL/A MP3 Player Logo
127 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
