Question about Indesit Washing Machines
FAULTY WASHING MACHINE
When the drum turns there is a grinding noise especially when spinning also i have noticed some brown/orange marks on my washing recently like rust stains. prior to the grinding noise starting i noticed an increase in the noise when spinning
  • becksf Jun 28, 2008
    it is an indesit machine. many thanks for your advice i think your very precise with your solution so i am now in touch with the company as the machine only 18months old so hopefully they will replace it.thanks again.
  • 481 Answers
Is it a GE or Hotpoint? if so it is the main bearing. the center seal might have leaked water on the bearing.  if you look inside the washer you will see a ring of rust splatter inside the case of the washer. if this is the case than you have to change the transmission or buy a new machine.
transmissions are $200+
Posted on Jun 27, 2008
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
Loud grinding noise meile washing machine drum when spinning?
It can that the spin drum is touching the body if not you can leave it until its broken my machine is doing tht also
Sep 17, 2014 | Miele Washing Machines
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
Loud Noise on Spin Cycle
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 16, 2013 | Washing Machines
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Grumbling Noise on Spin Cycle
If there is any form of grinding at all when the drum is turned than the rear bearings in the machine is going bad. This will only progress an get worse, then eventually start leaking and grinding and finally lock up.
Apr 26, 2012 | Bosch Washing Machines
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
Washing machine makes grinding sound when drum is turned
not enough info, but one or two answeres come to mind. Either your bearings have collapsed or something has managed to find its way between the two drums. Either way, unit has to be opened and this becomes a little technical.Grinding especially when spinning indicates 2 bearings and a seal to be replaced.(all done from the inside).
Sep 14, 2009 | LG Washing Machines
Washing machine problems
Sounds like the bearings in the drum may have failed, was it vibrating irratic on full spin before it stopped?
Mar 07, 2008 | Washing Machines
Washing machine spin with noise
I am a recently retired appliance engineer of 20 years sounds like the dreaded drum bearings, to check, switch off and open the door and try to move the inner chromed drum in the direction it should not go (pull towards you with your hand near the rim edge just behind the door seal) (and not too much force)if there is any play movement or it rattles then yes its confirmed, if the back of the machine is removed you may also notice brown rust water marks coming from the center rear of the drum just behind the center of the pulley always work with safety with the plug removed, if i have helped please rate me, and if i am correct (sorry) could be an expensive repair
Sep 09, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
190 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
