Question about Toshiba Computers & Internet
I have replaced my RAM but now when I turn on my laptop there is no hard disk drive recognised. What can I do?
  • 39 Answers
It is a laptop. most likely the power and the data cable are 1 and the same for the hard drive. have you tried to change the ram back?? if not do that first and make sure it isn't bad ram. if you do put it back and it works then it is incompatible ram. if you had to remove the hard drive to change the ram then go back in and make sure the hard drive cable is plugged in good at both ends (mother board and hard drive)
Posted on Jul 07, 2008
    Scholar:
  • 70 Answers
Please check the power cable for the hard drive along with the data cables.
Also reseat the ram.
Regards
Mohammed
Posted on Jul 04, 2008
  • 148 Answers
You have to modify your computer setup by telling it about the new RAM. Have you done that?
No Bootable Device
Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 25, 2012 | Acer Aspire One PC Notebook
My laptop doesn't recognise external hard drive
Most Windows versions:
Go to the diskmanagement (run compmgmt.msc) option Disk management.
Locate the drive and add a driveletter.
If the drive is not shown in the list, you need to check your USB drivers or connectors.
Jan 15, 2012 | Medion Computers & Internet
Sir my inspiron laptop b130, intel pentium processor 1.70 mhz 598 mhz, it is suitable for upgration r not? ram 1gb. 40 gb hard disk.? I need 2 gb ram and 500gb usb hard disk for oracle applications...
Max RAM for that system is 2GB
http://www.crucial.com/store/listparts.aspx?model=Inspiron%20B130&Cat=RAM
The question is whether there are 500GB hdds for that system. The largest PATA HDD I found was 320 GB
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4600076&CatId=2675
and there is no guarantee the BIOS will recognise a HDD that large as PATA HDDs require BIOS support for the drive size where SATA HDDs will pretty much work.
My recommendation is to retire this system and BUY a new one.
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=631874&csid=_23
Sep 10, 2011 | Dell Inspiron B130 Notebook
I turn on my Laptop and the fan will spin and the Hard disk light will turn on as well as the power light (obviously) But the Hard drive doesnt spin up and the screen stays blank no lights no nothing i...
Remove all of the ram, turn the laptop on if it does not beep you have a bad motherboard. If it beeps replace the memory and remove the hard drive turn on the laptop and see if it posts. If it posts without the hard drive then the hard drive is bad. Otherwise it is probably still a bad motherboard.
Apr 24, 2011 | Computers & Internet
I just put a new 9 cell battery, two new 2GB ram cards & a new, blank hard drive in our Dell Inspiron 1525. But the screen does not seem to work when I turn it on, or after I put in an installation...
Remove the battery, and connect the AC power. Then, try to start it.
Disconnect the AC power, and remove the "new" disk-drive.
Then, connect the AC power, and try to start it.
Disconnect the AC power. Remove the "new" RAM, and put the "old" RAM back in.
If it does start, add the "new" disk-drive, and try again.
If it does start, add the "new" RAM, and try again.
Jan 15, 2011 | Dell Inspiron 1525 Notebook
When I connect it to my laptop (or ANY other computer/laptop) the blue light on the external hardrive turns on and I can feel that it is working, but it simply doesnt get read, the computers dont recognise...
Open the enclosure.
Separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a 'slave' disk-drive in a desktop computer, and see if you can read the files.
If not, search online for a professional 'data recovery service' -- for a FEE, they can repair a disk-drive just long-enough to copy your files onto a new disk-drive.
Oct 26, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
Tried installing 4gb memory on to acer aspire 5720z notebook running vista 32bit, they would not be recognised. Have now installed vista business 64 bit & the 2 x 2GB new memory is still not...
  • CPU Section:
  • Microprocessor Full Name:Intel Core 2 Duo processor T5250
  • Microprocessor Manufacturer:Intel
  • Microprocessor Speed (GHz):1.5
  • L2 Cache (KB):2 Mb
  • Frontside Bus (MHz):667
  • Memory:
  • Memory Speed (MHz):667
  • Memory Type:DDR2
  • Memory Size (MB):2048 Mb
  • Max Memory Size:2Gb
  • Hard Disk Drive:
  • Hard Drive Capacity (GB):80 Gb
  • Hard Drive Type:S-ATA
As you can see from my printout from the web site, this laptop doesn't appear to support more than 2Gb of RAM.
Sorry.
Oct 18, 2010 | Acer Aspire 5720 Notebook
Portable hard disk fell its not being recognised
The drive has failed, Contact the manufacturer for a replacement and if u need the data back, contact a data recovery company :)
Apr 14, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
Hard disk recognised but not show up in my computer
Check the BIOS configuration to see if it deects the hard drive.
When you boot up the Samsung, does the hard drive spin up, if it does not spin up or makes a clicking sound the the hard drive is faulty.
To get your laptop operating again, replace the hard disk and install Windows on the new hard disk.
Jul 22, 2009 | Samsung NC10-14GW Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
