Question about Panasonic PT-47WX49 47" Rear Projection Television
Great Can you please give me a source and/or part number  where I can find the resistors.  i will just replace them both, since I do not have a resistor tester! Thank you. Omar
  • Panasonic Master
  • 8,617 Answers
There are 3 ratings for the resistors and there are 4 of each rating for each IC they are 2.2 ohm 1watt 2.2K ohm 1 watt and
3.3K ohm 1 watt. You can get replacements here.
http://servicemanuals.vstore.ca/
Posted on Jun 27, 2008
I have an early 450 mccullock chainsaw could be 50 yrs old still in great nick but needs kit in carby can these be sourced or replaced with another carby please
mcculloch Mac 450 chainsaw flatback carburetor
will take a long time to find a full carby for sale
same with a non working 450 mccullock chainsaw
by the pictures the newer carby designs wont interchange
this site might give you a lead to a carby kit
Aug 17, 2016 | Garden
Convergence PROBLEM pHILLIPS mAGNAVOX 60" rEAR pROJECTION
All i can say is that this is very common.May be it is not the convergence circuit in this case. it is the power supply not giving the convergence circuit the power it needs to run. there are several parts that need to be repalced here.
Or may be the convergence amplifiers need to be replaced. They're on the Small Signal Board (the one with the tuner[s] on it) and the part on the amp's (there are two on them, replace both) start with STK and will be followed by some numbers and pssosibly letters, such as STK392-110.
Goodluck,
Please don't forget to rate the solution.
Apr 11, 2008 | Philips 60PP9202 60" Rear Projection...
I have a sylvania lc320slx 32 inch tv and it wont come on it just stop working it like its not getting any power
The solution will be to replace the inverter board. This is a common failure in this TV. Power supply start up resistors on the inverter board, R1943, R1944, R1945 may be open or have changed values. The values of each should be R1943 at 330K, R1944 at 330 and R1945 at 39. These are ohms of course. If the original values of these resistors are different, please use the values I gave you. Of course this info is good if you want to rework the original board. In many cases the inverter board may be replaced. The inverter part number you need, will be located on the board. Look for numbers A91 or A94, these are prefixes.They are followed by 10 more numbers and letters. Show this note to a TV repair shop. knowlege in this area will save you a few bucks. That's why you asked me. Thanks for asking and show all hands of support!
Aug 31, 2011 | Sylvania LC320SLX 32 in. LCD TV
1998 infinity I30 heater quit working, no heat, everything else AC and is working.
you dident give much info to go off of, but check the resistor, and the blower for being faulty. unclip the harness to the fan, and give it a power and ground source manually, if it kicks on, the try replacing the resistor. if none of this applies, then check to see if the cooling system is full and flowing, a stuck thermostat will block flow to the heater core.
Dec 31, 2010 | 1997 Infiniti.5 J30
My sharp 910sh IMEI-353677015329954 please unlock code give me
just try the obvious codes ...1234, 0000, ****
OR
Here is some great source to solve any kinds of Cellular Phones problem.
» Nokia Solution
» Motorola Solution
» Sony Ericssion Solution
» LG Solution
» Samsung Somution
Here is some another Great source to UNLOCK any kinds of Cellular Phones.
» Nokia Unlock Code
» Motorola Unlock Code
» Sony Ericssion Unlock Code
» LG Unlock Code
» Samsung Unlock Code
OR
you enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and
get the puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted
then
Nov 08, 2009 | Cell Phones
NO SOUND
C14 was leak and resistor R2 burn out, I replace C14 with 0.1 uF and R2 with a chip fuse, sound after that was great at the speakers.
A.S.
Apr 18, 2009 | GPX PD708B Portable DVD Player
BLUE BULB CONVERGENCE
Replace the convergence ICs and feed resistors. You can get replacement ICs and resistors at the following link with installation instructions. If you leave them a email with your model number they will tell you the correct ICs and resistors for your model set. Heres the link.
Nov 26, 2008 | Hitachi 53UDX10B 53" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Hourglass Picture
it easy to locate the fusible resistor in the power module PCB,it look like a resistor but white in color,normally printed soc xxxx (2100) on top of the component. After you replaced the STK392-110 , you need to re-alight the convergence setting again.hope it will help.
Aug 03, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
