Question about Canon NP 6050 Copier
Canon photocopier Getting an Error Message E020 Change the power switch to off then on
I have a Canon Copier 6050 & right now its showing error Msg code : 800 . Please assist me to solve the same
Posted on Jul 28, 2009
  • Canon Expert
  • 287 Answers
Title : E020 Error Code Problem :
When you have followed all the steps from the troubleshooting guide in the Service Manual and still have not resolved the issue, here are some possible areas that might be related.
Solution :
1) Confirm that the toner and hopper sensors are being wiped completely.
2) Check the Gear Train on the hopper assy it may be locked up.
3) A possible bad hopper unit cable. FG5-5016-000. See The Parts Catalog page 620-2 item # 60.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Posted on Jun 29, 2008
The copier is canon,image runner 2520 newly purchased, has been powered,but brings error code e000020, and does not photocopy.
e000020 is error with toner unit,
several possibility :
- The toner is empty
- The developer failsto be replenished with starter developer properly.
- Related developing unit
- Ahopper motor error is identified by the detail code of E020. However, it may be identified by E02x according to need
Jul 20, 2011 | Office Equipment & Supplies
I am getting e020 error switch main off and on again and again
e020 error is of the main fuser unit u can solve it by press *28* then goto copier then function then clear and clear err dc-con err-hist jam-hist and pull both 1st and 2nd drawer now restart and when the screen is ok again restart then on main screen insert both drawers ur err will be removed -tushar sharma tushar@easy.com -9403343433
Mar 22, 2011 | Canon imageRUNNER 600 Printer
My Ir2800 canon photocopier is not functioning, if I switch the main power button on, I get an error message on the screen wit the code E000003-0000
these is temperature related error, fixing fault.
First you need to try cancel it, follow these steps:
turn on the copier
press *
press 2
press 8
press *
select COPIER
select FUNCTION
select CLEAR
select ERR
OK
turn off and on
If these doesnt helps change fixing film assy ( heater )
Hope that helps
Aug 16, 2010 | Canon Office Equipment & Supplies
Error
CLC1150 problem code E020 0181
what is this? The machine has been off/on and we also this problem
info@setobemmel.nl
Jan 31, 2010 | Canon CLC 1150 Color Copier
Canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
Canon NP 6050 Copier Logo
566 people viewed this question
old marine
old marine
