Question about Apple iPod MP3 Player
My Ipod stopped playing all of a sudden
It won't play as many times as i press play. It turns on and I can see that it says play and pause or even what song it is on but no matter what it does not play. It also will automatically go through all the songs on the ipod and then I cant stop it from doing that. What should I do?
Try running the restore from itunes
Posted on Jun 27, 2008
30gb ipod freeze up cant shutdown to reboot
Slide the Hold button on the top of the iPod so no red mark is visible. Press the main menu button until you see a long list of options (Artists Albums Songs Extras......) use the scroll wheel to find the sleep press and hold the center button in or Locate the Play/Pause button on the iPod. The Play/Pause button is at the bottom of the wheel around the select button. Press and hold the Play/Pause button until the unit powers off, about three to five seconds. Press any button on the iPod to turn the power on.
Feb 14, 2013 | Apple iPod Audio Players & Recorders
Trying to swicth off my i pod
Feb 03, 2013 | Apple iPod MA446LL/A MP3 Player
Operating manual for Plain Lazy Alarm Clock iPhone/iPod Speaker Dock
No instruction manuals for the 'Plain Lazy' ipod docking station/alarm clock found on line :-( So after tinkering with the buttons for quite a while, II have worked out how to set the clock. Press & hold the play/pause button & at the same time press the skip back button once....let go of both buttons. Then immediately press the play/pause button again once & the clock numbers will start flashing. Press the skip back button to adjust the hours & skip forward button to adjust the minutes. Press the play/pause button to set!
Aug 04, 2012 | Audio Players & Recorders
IPod classic stopped shuffling this weekend. I've had it for several months and it's worked just fine, but all of the sudden it stopped shuffling songs within playlists that were set to shuffle. ...
Hey press the play pause button and the enter button at the same time if it has a lock move it baca and forte 6 times while holding play pause button and enter/centered button for 6 seconds, that should solve from freezing ipods to non functioning well :)
Jul 20, 2011 | Apple iPod touch
I have just been given an apple ipod nano 4gb and dont know how to turn it on !
Push and hold the play/Pause button. (>II)
should come up in a couple of seconds.
Hope this is of some help.
Ed
Apr 26, 2009 | Apple iPod nano
My ipod isn't recharging or even turning on.
try putting the ipod into disc mode before connecting it to your computer to restore. Just in case you are unsure on how to put an ipod into disc mode, I have posted step by step instructions below. This is the only other option to restore the ipod and not need it repaired or replaced.
I hope it works for you :)
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Apr 25, 2009 | Apple iPod nano 3rd Generation
Buttons arn't working
Hi!
Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step until apple logo appears.
If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset your iPod
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
iPod not responding If your iPod does not respond to these steps, see additional steps in the "iPod troubleshooting basics and service FAQ".
Additional Information Apple releases new versions of the iPod Software Update application from time to time. These later versions may include new functions or improvements to existing features. Learn about updating iPod's software.
To return iPod to its original factory settings, use the iPod Software Updater utility to restore iPod.
Jan 30, 2009 | Apple iTunes
Shuffle not working, blinking green-yellow led.
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Jun 25, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Audiobook download
Playing Songs, Audiobooks, and Podcasts on iPod shuffle iPod shuffle allows you to play your audio files in a couple different ways—you can play songs, audiobooks, and podcasts in the order in which they appear on your player, or let iPod shuffle work its namesake magic for you (that is, shuffle the files by playing them randomly).
Show Me How
If you want iPod shuffle to play audio files in the order in which they appear on the player, move the switch on the top of the iPod shuffle to the play in order (circular arrows) position. If you want iPod shuffle to play songs in random order, move the switch to the shuffle (crossed arrows) position.
ip02_playfnky_04_shuflebutton.gif This iPod Shuffle is set to shuffle.
To play music, an audiobook, or podcast, just press the Play/Pause button. To skip to the next song (or a different song if you're in shuffle mode, or a different chapter if you're listening to an audiobook or podcast), press the Next/Fast-forward button. To fast-forward through the audio, hold down the Next/Fast-forward button. To go back to the beginning of a song (or the previous chapter), press the Previous/Rewind button; press this button twice to go to the previous song or hold it down to rewind through the file.
To stop play, press the Play/Pause button during play. To turn off iPod shuffle, move the switch to the Off position (you shouldn't see green beneath the switch).
Jan 24, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod MP3 Player Logo
44 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
