Question about Xerox Phaser 8200 Laser Printer
SERV REPORT FAULT 15.004.45-6608
  • 2,072 Answers
The drum heaters are not working. They are 2, 150 watt halogen lamps in series in the machine, One or both have blown out.
Posted on Jun 27, 2008
  • Rick Kasper Jun 27, 2008
    Here is the replacement procedure.
    First off purchase if you can, Sylvania 150 watt, 130 volt anti vibration halogen lamps. Less then $20 for the pair.
    1. remove both side covers, i screw each in the back and 1 on each inside part of the upper cover.
    2. On the left side remove the registration clutch, gear and black drive belt.
    from the front remove the maintenance tray, and the 2 green guides that
    is slides in on. One torx bolt on each guide and carefully manipulate
    them out.
    4. Remove the upper stainless steel transport cover, upper front, about 11 inches wide and 3 inches in height, 2 torx bolts.
    Be careful in removing the registration transport, it is in the middle
    front, has black rollers on it, stainless steel also. One torx on the
    upper right side of the transport and a C clip on the left, sort of
    hiding against a bearing. Once the torx and clip are removed the
    transport can be gently slid to the right and out. E CAREFUL NOT TO
    BREAK the black registration sensor flag...
    6. Remove 2 plugs on the
    right side about 4 inches back and 3 inches from the bottom of the
    frame one white plug and maybe a black plug.
    7 Back to the front ,
    look inside you will see 2 beige type blocks with torx running into
    them, remove those 2 torx and slip the heater out. Remove the spring
    clips holding the lamps in place, remove the old lamps, replace BOTH,
    clean the contacts on the ends where the new lamps connect and re
    assemble. Just take your time. Should take an hour or less.
DIC reports "serv stability system".
dirty or wet sensor wires .clean them.
Dec 19, 2013 | 1998 Cadillac Eldorado
Flashing f2 fault
Faulty fan I think.
Nov 17, 2013 | Liebherr Refrigerators
Rover 75 diognostic reports fault on cylinder 3 & 4
that simply means the #3 and #4 misfires. check the resistance of the coil if it is within the range. if not,replace the coils.
the scan tool tells exactly fault.
Feb 09, 2012 | 2000 Rover 75
I bought the car ,a week ago , and the serv light keeps coming on ,???
serv light on a renault does not indicate it needs a service it means the vehicle has flagged up a fault and you will need to get it on a diagnostic tool and see what codes you get.
Jun 14, 2011 | Renault Le Car Cars & Trucks
Service engine light stays on. changed oil last week.
The service engine light does not refer to oil changes, it is used to check for engine fucntion and emmision control sensors. Most likely you have a fault in one of the emmission control sensors.
Dec 04, 2010 | 2003 Chevrolet S-10
I get an error message that says "Printer Error - Contact Service: Report Fault:" Whats does it mean and how can I fix it? Thanks
That means the 2 halogen lamps that serve as the drum heater have gone out. Either one or both have blown.
They simply are 2, ,, 150 watt halogen lamps that you can replace, Takes about an hour to do, I can send you instructions if you want.
E-mail me ,,,
Jul 14, 2009 | Xerox Phaser 8200 Laser Printer
2005 Crown Vic indicator light question?
This is from your owners manual, the little wrench means the following:
Electronic throttle control:
Illuminates when the engine has
defaulted to a ’limp-home’ operation.
Report the fault to a dealer at the
earliest opportunity.
U have some kind of serious fault, u need to go to the dealer.
Jan 14, 2009 | 1994 Ford Crown Victoria
What does fault code PO122
A P0122 code means that the the car's computer has detected that the TPS (throttle position sensor) is reporting too low a voltage. It coud be a bad TPS, or a wire problem.
Oct 28, 2008 | 1997 Ford Mustang Cobra
Xerox Phaser 8200 Laser Printer Logo
55 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
