Question about Microwave Ovens
MESSAGE DISPLAY H98
ON THE DISPLAY ON THE MICROWAVE IT KEEPS SAYING H98 I'VE LOOKED IN THE MANUAL BUT IT DOESN'T TELL YOU WHAT H98 MEANS OR HOW TO GET RID OF IT. CONSEQUENTLY DUE TO THIS MESSAGE THE MICROWAVE DOES NOT WORK. PLEASE HELP.
PAUL.
  • Anonymous Apr 11, 2009
    it not woking
  • Anonymous Mar 21, 2014
    1S on display. What does this mean? Microwave not working
  • Microwave Ovens Master
  • 9,086 Answers
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
Unable clear h98 code on panasonic nn-sa651s
It would be best to replace your microwave. The h98 code means there's an issue with a circuit. You can have it repaired but it would be cheaper to buy a new one
Jan 19, 2015 | Panasonic Microwave Ovens
It come up said h98
Would you care to tell us the make and model of the machine saying so?
Mar 04, 2013 | Microwave Ovens
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
May 31, 2012 | Microwave Ovens
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Microwave will not work...display reads H98
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Dec 14, 2009 | Panasonic Microwave Ovens
Need a manual for a panasonic inverter combi microwave oven model number NNA514A
my microwave is saying h98 what does that mean. it's a panasonic inverter.
Aug 05, 2009 | Panasonic Microwave Ovens
I HAVE MIC. NN-SD997S ,IT DOES NOT WORK ,MESSAGE SAYS "H98" .
This displaying indicates a
problem with the microwave
generation system
This is for your dealer to resolve
Mar 11, 2009 | Panasonic NN-SD997S Microwave Oven
Microwave Ovens Logo
6,687 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
