Question about Frigidaire FAH125P2T Air Conditioner
Front panel FAH125P2T
How to remove complete front panel?
NO clips at the sides NOR srews at the front. I did remove the two srews at each side but I don't want to break anything in order to remove the front panel which doesn't come off the way I'd expected. Thanks for trying ;-(
Posted on Jun 27, 2008
  • 958 Answers
Look for some clips at the sides,or screws at the front. the top portion is also clipped to the metal housing.
How to replace the blower in a Senville SENA-24HF Mini Split Wall unit?
You have to pump down the a/c and remove the indoor unit. If not
The bottom of front side of front panel there are 3 screws. Unscrew and remove the front panel. Then unscrew PCB board. Then Unscrew the coil, and slightly keep upward and replace the blower.
Sep 08, 2015 | Senville 24000 BTU Energy Star Ductless...
Need to remove front panel located under the filter cover
Press around the panel edges while pulling back. There are probably plastic clip locks that need to be depressed to unlock. Flex carefully, taking care not to break the plastic cover.
May 13, 2015 | Samsung AW1293L Air Conditioner
Frigidaire MOdel FFRE1833Q@ left panel does not show indicator light
Good Afternoon Friend,
I understand the left panel of your Frigidaire air conditioner, model# FFRE1833Q, does not show the indicator light. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and see if the indicator light comes on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire FAH125P2T Air Conditioner
Water dripping from the front of carrier 42p100c air con how do i completely remove the plastic covers so that i can clean out and inspect the system to see if there is ice forming and also i want to blow...
It is necessary that the A/C is mounted with a tilt to the rear so that the water that drips while the compressors works from the cooling pipes will flow off to the drain at the rear.
Look on the sides or lift the front filter covers to get access to the screws holding the front panel to the main frame. now remove and PULL out the unit with the power detached.
You need help to hold on the main unit when pulled out , clean and reset using jet water/air. Lubricate if needed on the fan motor, clean the fins by blowing or brushing.
Apr 21, 2011 | Heating & Cooling
How to remove front cover for cleaning
I don't know too much about your particular make / model but most window units have a 1 piece front cover which is usually held on to the main cabinet with 1 or 2 screws at the sides and 1 or 2 behind the filter panel. You will need to remove the front panel to remove the vents as they are usually fitted from behind the panel.
May 31, 2010 | Friedrich QuietMaster SM18J30BR Air...
How do I remove the front panel to clean the coils in the front? I have the panel free at the top, bottom and sides but seems to be hanging up/caught in the middle, between and below the vents? Fedder...
front panel has one phillips screw in it. remove the air filter and you will see it. Once you remove the screw, grasp the lower front sides of the cover, where the plastic meets the metal, and gently pry it outwards and towards you. there are plastic clips that hold the cover in place. One on each lower side and three on top.
Apr 13, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
Can you recommend purchasing a model FAM18HS2A Frigidaire
NO! I have one that is only 2 years old, and the control panel has quit working. I have turned in on and off and following all of the recommendations. I will need to order a new control board to get it working again.
Apr 02, 2010 | Frigidaire FAH125P2T Air Conditioner
How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Feb 23, 2010 | Fujitsu 18R1 Air Conditioner
Carrier furnace burner will not on with front panel close.
Sounds like a combustion air issue and by removing the front panel it lights and runs. Is there a PVC pipe connected to the cabinet that may have a blockage in it? There may be 2 pipes, one for exhaust and one for combustion air. Would not hurt to check both.
Jan 02, 2010 | Carrier Heating & Cooling
Front Panel
"Look for clips and screws" and find a joker ;-)
Thanks for nothing! This place is a joke, IMHO.
Jun 27, 2008 | Frigidaire FAH125P2T Air Conditioner
Frigidaire FAH125P2T Air Conditioner Logo
468 people viewed this question
Top Frigidaire Heating & Cooling Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
