I think you are talking about the Memory Card (Memory Stick). Hope you installed it with the adapter. If there's no problem with the slot or with the pins inside the slot, it should pop out when it's pushed in with a "click" sound. Push the memory card and release, it will be ejected. But if there's problem, you'll need a pair of tweezers to pull it out. It will not be able to easily pulled out, hold it very tight and push in once and then pull out, it should come out.
If a pin or few pins are bent or twisted, it should be done by a technician or by a pro, otherwise you may damage the card.
This is all what I could suggest you about this. I wish you good luck.
Thanks for using FixYa.
