Question about Frigidaire FAH125P2T Air Conditioner
Front Panel How can I take off the front panel after removing the 2 crews on each side?
"Look for clips and screws" and find a joker ;-)
Thanks for nothing! This place is a joke, IMHO.
Posted on Jun 28, 2008
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Center console removal
Well, this good to be interesting to say the least, and probably long as well. By my gm. service information your going to need to take out the front bucket seats so the sides of the console can come off.
Remove the left front seat . Refer to Bucket Seat Replacement .
Front Floor Console Extension Panel
Retainer Clip (Qty: 5) same for right side.
showgif.do?image=1875475
Callout
Component Name
Preliminary Procedure
Remove the right front seat. Refer to Bucket Seat Replacement .
Front Floor Console Accessory Trim Plate Assembly
Procedure
Use a flat bladed plastic trim tool in order to release the console accessory trim plate from the console assembly.
Retainer Clips (Qty: 5)
Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement.
Front Floor Console Accessory Housing Screw (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
2 N?·m (18 lb in)
Front Floor Console Accessory Housing Assembly
Procedure
  1. Disconnect the electrical connectors.
  2. When replacing the front floor console accessory housing assembly, transfer all necessary components
  1. Remove the rght or left front floor console extension panel. Refer to Front Floor Console Extension Panel Replacement - Right Side or Front Floor Console Extension Panel Replacement - Left Side .
  2. Remove the front floor console cup holder housing. Refer to Front Floor Console Cup Holder Housing Replacement .
Front Floor Console Rear Trim Panel Screw (Qty: 1)
Tighten
2 N?·m (18 lb in)
Retainer Clip (Qty: 4)
Preliminary Procedures
  1. Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement .
  2. Remove the right and left front floor console fillers. Refer to Front Floor Console Filler Replacement .
Front Floor Console Armrest Assembly Bolt (Qty: 4)
Tighten
9 N?·m (80 lb in)
Procedure
Position the armrest assembly out of the way leaving the electrical harness attached.
Front Floor Upper Console Trim Plate
Procedure
Lift the rear of the trim plate first, releasing the retainers securing the trip plate to the console assembly.
Retainer Clips (Qty: 4)
Front Floor Console Replacement (Enclave)
showgif.do?image=1858392
Callout
Component Name
  2. Remove the right and left front floor console extension panels. Refer to Front Floor Console Extension Panel Replacement - Right Side and Front Floor Console Extension Panel Replacement - Left Side .
  3. Disconnect the automatic transmission range selector lever cable. Refer to Range Selector Lever Cable Replacement .
Front Floor Console Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Bolt (Qty: 10)
Tip
Before installing the right lower forward bolt, ensure that the console wiring harness is tucked below the fastener location to avoid driving the bolt into the harness.
Tighten
9 N?·m (80 lb in)
Front Floor Console Assembly
Procedure
  1. Note location and routing of the front floor console wiring harness prior to removal of the front floor console assembly to ensure proper reinstallation.
  2. Disconnect the electrical connectors.
  3. With the aid of an assistant remove the console assembly from the vehicle.
  4. When replacing the front floor console, transfer all necessary components.
h4hqqpweof7+aaaaaelftksuqmcc
arzs+0tf0j6faaaaaelftksuqmcc
Jan 10, 2015 | 2008 Buick Enclave
What is the kick panel?
Hi Farm Gal, The kick panel is the panel inside the vehicle (usually made of plastic) mounted on the side of the cabin in front of the front doors. The vertical panel alongside your leg and foot. Regards John
Oct 20, 2012 | 2003 Ford F250 Super Duty Crew Cab
Remove front panel on kenmore washer dryer stack model110.26182
Model# 110.88752799 Kenmore stacker washer/dryer
Q; How do I remove the front control panel? (to remove the timer dial, to replace a switch, etc)
A: reference diagram- http://www.searspartsdirect.com/partsdirect/partsdirect/printSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK1105180-00001.png
-remove four crews (#8 on diagram) from left and right sides.
-remove one screw (at #21 on diagram) from the bottom of the panel.
-remove #7 panel from the left and right side
- this will expose a thin metal catch (#9) on each side. With a small finger or screw driver, push down on the top of this metal strip where it bends horizontally. This will compress the spring (#14) and release the catch.
- the control panel will fold down now.
Jun 01, 2012 | Kenmore 98702 Stacked Washer/Dryer
How do i remove the wing mirror (power adjust & power fold) on the ford f250 super duty?
Roll the window down first, you will need 2 hands. Pull the small cover off that is at the top front of the door pannel. You will then disconnect the wire connector and remove the three 11mm nuts that are holding the mirror in place. Pull mirror out and replace.
If you dont have just that little pannel you will have to remove the door pannel. If you dont have power windows pull the cover out on the window crank and move it to the side, there will be a screw holding the crank in place. Remove it. If you do have power windows remove the window control switch plate (it will just pop up using a small screwdriver) and disconnect the wires. If equipped, remove the front door trim panel reflector or the courtesy lamp lens. Then remove the screws. DO NOT pull directly outward on the door pannel, something will brake. Remove the front door trim panel by pulling it straight upward.Lift and remove the front door trim panel. Then the nuts holding the mirror will be visible, remove and replace the mirror.
Dec 07, 2010 | 2000 Ford F250 Super Duty Crew Cabs
NEED TO LOCATE THE INERTIA SWITCH ON A 1997 F350 7.3L CREW CAB .MY MANUAL SAYS ITS ON THE FRONT PASSENGER SIDE COWL(BEHIND THE TRIM)BELOW THE INSTRUMENT PANEL.I HAVE TORN APART MY WHOLE DASH AND FRONT TRIM...
my Ford manual says the same thing...
"Behind the right Kick panel"
you should not have to remove anything to get to this and there should be a cutout in the trim panel where the switch is located
could it be someone removed it?
also check the drivers kick panel
Apr 11, 2010 | 1997 Ford F350 Crew Cab
How do you remove the front panel on LG model # DLG0452W . I want to replace the igniter glow.
Disconnect the washer from the power source. Use a putty knife blade to release the locks of the top panel. Insert the putty knife blade in the seam between the top panel and the front panel about 2 3/4" from the edges. Push until the locks are released and lift the top panel.
Open the door and remove the 2 screws from the bottom of the door opening. Remove the 2 screws from the upper side of the front panel and pull the front panel out. Disconnect the door switch connector and remove the front panel completely.
Feb 12, 2010 | Washing Machines
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. Remove front door trim panel.
  1. To install, reverse Removal procedure.
May 07, 2009 | 1994 Mercury Cougar
DRYER HEATS ,BUT DOESN'T TURN
FIRST UNPLUG UNIT!!
Remove 2 screws by filter area on main top.
Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
Nov 11, 2007 | Whirlpool LGR3624JQ Gas Dryer
Roper gas dryer
FIRST UNPLUG UNIT!!
Nov 08, 2007 | AEG T57800 Electric Dryer
Frigidaire FAH125P2T Air Conditioner Logo
608 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
