Question about Tomtom GO 510 GPS Receiver
My tomtom doesnt turns on. It shows the green led when pressing the power button, but doesnt show anything. It doesnt charge and doesnt show any led while on charge. I tried the reset for 10 sec (and 15 sec too) without card.
  • fenixorg Jun 27, 2008
    My tomtom is go 510
  • fenixorg Jun 30, 2008
    Problem with the charger.
    Working with the mobile charger
Remove the micro sd card from your TomTom. Look at the bottom of your unit, where the copper contacts are (where the unit mounts to the windshield mount). You will notice a "cut-out" in the plastic case, just above the contacts. The reset button is there. Use a paper clip and depress this button for 15 seconds. Now press the power button, and it should turn on. Now replace the sd card.
Posted on Jul 02, 2008
My TomTom One V3 won't switch on. The green light shows it as charging but it won't power up. Tried reset as discussed with TomTom
If reset not worked, then must open up, take out battery and then reset, then you must hook up USB and upgrade software, also maybe need to get new battery too, often battery seems OK, but not,.
Apr 10, 2010 | Tomtom ONE 3rd Edition GPS
My tomtom doesn't turn on
the green light shows when i am charging my tomtom but it doesn't turn on.
Aug 19, 2009 | Tomtom GO 720 GPS Receiver
My dell laptop doesnt turn on
Remove the bezel avove the keyboard with a small flat head screwdriver. Press the power button with your finger and see if it powers up. If it does, just replace the bezel. If not, then you could have a bad system board.
Does the battery show a charge when you press the button located on it? Does the power adapter show a green light when it's plugged into an A/C outlet?
Dec 31, 2008 | Dell Latitude D600 Notebook
My tomtom go 910 will not switch on it has the green light on at the top left when plugged into a charger but nothing turns on when pressing button for 2 seconds any ideas??
In general I find these sort of problems can be fixed by the below
If the Tomtom loses battery power it might cease to function with a blank screen but will show a green light when you charge it. The trick is charge it on the mains charger for at least two hours. Then reset the device with a paper clip. If you get no reponse hold down the on button for at least 20 secs and the device will show the Tomtom logo and play a drum roll and startup normally.
Sep 03, 2008 | Tomtom GO 910
Changed ink jets alarm flashing number 5800 showing
Hello Saron Girl,
its not 5800 its 5B00
7 times LED Blink Waste ink absorber full [5B00] - Ink absorber (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
4 times LED Green Waste ink counter resetting
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Regards,
May 14, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Tomtom not switching on
I had this problem. had it plugged in charging and then pressed the the reset and the power button at the same time for about 30-50 seconds and then after that pressed the power button and so far so good
Apr 02, 2008 | Tomtom GO 700 GPS Receiver
Battery low
This may seem like a dumb question, but have you tested the lighter socket to see if it's working? If the TomTom is plugged in, you shouldn't get a low battery warning.
Feb 18, 2008 | Tomtom ONE GPS Receiver
Tomtom One screen problem
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 04, 2007 | Tomtom ONE GPS Receiver
TomTom 500 won't power EITHER!!!!
Guys make sure you know where the reset button is . Ie for tomtom 500 it is at the back and you have to unclip from the adapter.
Jul 04, 2007 | Tomtom GO 300 GPS Receiver
GPS Logo
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
