Black area on screen,
Every nite at the same time, i get a large black out area on my screen, it only pop's up on this tv, not on the others. when i push the DISPLAY button ,it go's away for a few seconds ,then it pop's up again. it only does it from 10:30 til 11:00 pm. i'm going nuts. dc
  • omsoc Jun 28, 2008
    JASON, thanks for your help, i worked on the caption menu til i was finally able to get it off , thanks , omsoc
    Scholar:
  • 78 Answers
Hi omsoc,
This could possibly be an issue with closed captioning. While some closed captioning is a marquee-type text near an edge of the display, your television may have an option turned on to display a different channel of captioning that would likely display a large black box on your screen if there is no data to display. This would explain why this would take place suddenly at the same time each night, as well as why pressing the display button would cause it to disappear. I suggest you look into your menu to try turning this option off, then watch the channel you normally watch at this time. If this does not resolve the situation, I recommend you contact your manufacturer’s product support line.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 27, 2008
It was the closed caption button..I turned it off then the black area disappeared
Posted on Jul 12, 2011
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
Black box on screen
Without a picture of it it's hard to say what you mean. Sometimes on a CRT TV the vertical scan doesn't fill the screen, but that would cause a black band both top and bottom. The usual cause is a capacitor drying out. But only a qualified tech should look into that.
Jan 04, 2014 | Philips Magnavox TS3260C 32" TV
A large pop and I lost my screen, it turned black
Its not the CRT, its the Y Sustain board.. This happened to mine 30 minutes ago.. and has happened to every owner of a plasma tv that uses the toshiba Y Sustain board..
Jul 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Large black area in the middle of my screen
After doing some research I found out the the closed captioning or text box was accidentally turned on. You can try to turn off closed captioning and that might work, fortunately it worked for me!
Nov 13, 2008 | Televison & Video
Unwanted rectangular black area appears on screen blocking 40% of picture
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
Nov 07, 2008 | Durabrand DWT1304 13" TV
Black box in center of screen
The Panasonic call center helped us with this one. Our Closed Captioning had been turned on through the TV settings. This made us have a black box with everything besides our cable. Turning off CC on our TV Main Menu solved the problem for us.
Jul 24, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Black box showing up while viewing DVDs
This sound like a problem with the Closed Caption, on many sets if the C.C. is set to text a black box apears, and since it only happens on DVD you might look at the DVD menu and see if it has this Text featcher in the Closed Caption menu and turn it off
Feb 13, 2008 | Televison & Video
Go to your TV remote, in the menu find the closed caption or sometimes it is on the remote itself. Turn off the closed caption. this should solve your problem. Good Luck
Mar 28, 2007 | Sony DAV-C990 System
Televison & Video Logo
391 people viewed this question
Top Televison & Video Experts
