Yellow botch on lower left side of 50 in. screen
Check fluid level in blue tube
Posted on Jul 04, 2008
A yellow line going down the left side of the television
you likely have the "screen size" option set to allow the TV determine the best size (3:4 , 16:9, ...). Set it manually to 16:9 for HD channels or 3:4 for low-def channels.
The line should go away. This is a common problem on Samsung, Sony (Green line right side) and Phillips (yellow line left side).
May 05, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
I am trying to figure out proper wiring for 95 raodmaster stereo in atempt to correct botched job from previuos owner.Back speakers were cut and hot wire for power attenna!
Constant 12v + orange
Switched 12v + yellow
Ground Black/white
illumination grey/black
dimmer brown/white
antenna trigger dark green
left front speaker + tan
left front - grey
right front + light green
right front - dark green
left rear + brown
left rear - yellow
right rear + dark blue
right rear - light blue
Apr 04, 2010 | 1995 Buick Roadmaster
Large yellow blot on the left side of the screen.
that sounds like a very expensive repair I'm afraid
, it is the light engine that is bad
Larry D.
Aug 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Yellow tv screen
i have the same problem. I had to take the whole thing apart and found that the red filter has a burn pattern in it. I am still trying to find a red filter for it.
Feb 16, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Yellow discoloration on screen
the screen is yellow green color all the we have had it worked on once already does anyoblemne have any comments on how to solve this problems?
Jan 27, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hazy yellow spot in the left lower corner of the screen
It could be a cob web inside the tv or something laying on one of the guns, like a dead bug. If it's a cob web, you should be able to move the tv a little side to side and see it change from the moving air current. I would remove the back and vacuum off the lenses of the guns and look for cob webs. It's safe to touch and clean the lenses, just don't touch any electronics.If this doesn't fix it, it's probably fluid starting to cloud up in the guns or IC chip problems.
Jan 08, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Left side of screen going yellow and pink with leters in double
The convergence modules have gone bad Along with the new parts kit are fuses, diodes, and resistors that usually fry when these modules go bad. Depending on the model, there will be two and sometimes 3 of these modules that have to be replaced. Each module has 50 pins each that have to be soldered, so unless you have experience with complicated TV repairs, the cost to do that repair may be as much as a flat screen TV of the same screen size as yours.
May 12, 2017 | Mitsubishi WS-65711 65" Rear Projection...
KDS-R50XBR1 has a yellow hue in the lower right hand corner of the screem
Hi JimmyDeps
If there is a yellow hue I would guess that this a LCD TV right ?
Which means that the blue LCD has gone and will have to be replaced.
May 13, 2008 | Sony BRAVIA SXRD HD Home Theater Projector
Screen
Go to this link and click on the contact linkon the lower left side of the home page and leave the measurements of your screen top to bottom and side to side. They have used assemblies just measure what you see right up to the edge of the frame and they will add the extra 1/4 inch for whats inside the frame.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Hitachi 50FX48B 50" Rear Projection...
My ''9P5034C102" 50'' Philips Projection TV
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try www.magnavoxhelp.com - They have instructions and kits on their site.
Jan 26, 2008 | Philips 9P5034C 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
