Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Brake lights stay on 07 hd fxdb
My 07 hd dyna streetbob brake lights are staying on, the problem just started last night when i started the bike to head home from work.The bike rolls freely when in neutral i checked brake fluid for both the front and back brakes and checked the fuses
  • 27 Answers
Have you changed your bars? Check the micro switch behind the brake lever in the housing. Might have moved a bit.
Check that both filaments of the brake light are good and one is not broken.
While you have the brake light cover off check the connectors into the main body of the light. On my Bob (same year) They all plug into there and can be unplugged easily and re-inserted. One might have not been put in all the way home on assembly.
Hope it helps.
Posted on Aug 15, 2008
2006 Harley Davidson FXDWGI Dyna Wide Glide replace speedometer
Hi, Jax for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
How to Remove Replace the Speedometer on 2009 Harley Davidson Softail...
http://kt-trading.net/mcimport/mc/HD/HD.Service.Manual.Dyna.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2006-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Jun 30, 2017 | 2006 Harley Davidson FXDWGI Dyna Wide...
2007 dyna street bob will not turn over after warm up
Are the lights coming on? If not, check battery and battery connections for tightness. If lights are on, then I would check all fuses. Have you accidently hit the run/stop switch getting on bike?
Sep 01, 2014 | 2007 Harley Davidson FXDB Dyna Street Bob
Check engine light
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Harley Diagnostic Codes 04 to Present
Sep 02, 2013 | 2007 Harley Davidson FXDB Dyna Street Bob
2007 harley sreet bob fires but wont stay running
check that a piece of debris from the broken line has not got into the fuel system causing your grief.
Jul 14, 2013 | 2007 Harley Davidson FXDB Dyna Street Bob
Tail light on HD Dyna Low Rider is still staying on after pulling switch for rear brake pedal. What to do now?
Is it the talilliight or the brake light? If it's the brake light, check the front brake switch inside the right handlebar control. The plunger may not be working properly.
Aug 13, 2012 | Harley Davidson FXDLI Dyna Low Rider...
Dyna streetbob rear axle and spacers
I recommend to anyone wishing to do even minor work on their own Harley, buy the shop manual. With clear instructions I have been able to do a lot of work that would have cost more than the manual. Since the year 2000 I have replaced seals in the front forks, brake pads, and done all the oil changes myself which I know would have cost a lot more at the dealer. The manual is very detailed and gave me the confidence I could do those things safely and not have to worry about something going wrong on the road.
Because my older 2000 manual may not be accurate for your newer 2007 I am reluctant to tell you how to proceed other than to recommend you get a manual. If the cost of a shop manual is now prohibitively expensive try a Clymers manual. I believe I saw them on the internet for less than $40.
Last time I checked that won't even pay for one hour at the Harley shop. But there are some things that should be left to the factory trained techs.
Jul 31, 2012 | 2007 Harley Davidson FXDB Dyna Street Bob
Were is the oil drain plug on a 2007 dyna streetbob
It's under the engine on the flat part of the pan. Slightly to the right and rear of the pan.
Jul 24, 2012 | 2007 Harley Davidson FXDB Dyna Street Bob
Need to get inside fuel tank 07 streetbob 96 cube something loose fuelpump mabee how ?
You should be able to look in there with a flashlight and a small mirror.
I'm wondering if the fuel gauge is making the noise.
You will have to drain the tank and get in there with a bright light and a mirror. Get a small one on a rod that can be extended. Maybe you will find something in there. I bought a locking cap for my Harley before it even left the dealer. That helps to keep out mischief.
May 12, 2012 | 2007 Harley Davidson FXDB Dyna Street Bob
Does the oil light stay on when the ignition is on untill the bike is started?
you should have a 5 second delay from the time the bike is started for the light to go out
Jun 23, 2011 | 2003 Harley Davidson FXDWG Dyna Wide Glide
02 harley fxdwg brake light stays on
Make sure your rear brake pedal has freeplay in it. when you slowly push the lever down by hand you should be able to feel some freeplay. if not the the reason it keeps staying on is because the vibration of the motor is actually pumping up your brake ( light too ) and not releasing it until it bleeds off the pressure.
Jun 23, 2009 | 2002 Harley Davidson FXDWG Dyna Wide Glide
Lands Phones Logo
298 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
