Dust behind screen
Hi I have a JVC HD-52G787 and there is dust behind the screen which looks like gray blobs I took the screws out and only the ring around the screen came off. how do I get to the inside of the screen to remove the dust? Thanks Tom
2 ways. There are two access panels about mid screen on the sides of the cabinet. Or you can take all of the screws out and take the whole screen apart ,all the way down to the lens on the projector. It is up to you. If you are pretty mechanincally inclined then take the whole cabinet apart, as you will be able to clean more of the cabinet. Use a microfiber cloth to clean both the screen and the rear mirror. Hope this helps. I usually clean mine every three months or so.
Posted on Jan 16, 2009
Fan issue with hd-52g787 52 inch
The lamp is protected if fan does not work it has a thermal fuse that will cut power to lamp etc.
One of the real issues is the fans intake air from front of set and exhaust it out rear---sets and fans get coated with fine dust and cause problems including in some cases set shutting off.
Apr 29, 2012 | JVC HD-52G787 52" Projection Television
Have a jvc hd-52g787 with no remote how do i start autotuner using the front panel buttons?
Your gunna have to buy a universal remote, program your model number into the reomote and you should be good to go.
Aug 12, 2011 | JVC HD-52G787 52" Projection Television
Is the JVC model HD-52G787 or HD-52G887 able to receive digital siginals without the use of converter box?
It doesn't look like it.
Have a look;
http://www.retrevo.com/pdf/391dj496/4/Quick+Setup#q=JVC+HD-52G887
Hope that helps.
Jan 05, 2011 | JVC Televison & Video
Jvc 52" hd tv screen yellow
Have crack screen sign?Not fixable only require LCD changing,not buy able LCD screen only can buy it new from the tv compannies,but only sell as new tv only.
Jan 08, 2010 | JVC HD-52G787 52" Projection Television
Needs bulb
Just under $200 for the JVC hd-52g787
CLICK HERE to see the lamp and price.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 01, 2009 | JVC HD-52G787 52" Projection Television
I have a 52 jvc television and for some reason it wont turn on. the red and blue light in front will blink but there is nothing showing on the screen.
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Aug 03, 2009 | JVC HD-52G787 52" Projection Television
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Fuzzy blob on JVC Model # HD-56G787
my bulb went out in my 56" jvc hd-56g787 and i need to change it! i have a new buld how do i get to the bulb to change it?????????? thx jimmy
May 26, 2008 | JVC HD56FH96 56" Television
Televison & Video Logo
382 people viewed this question
Top Televison & Video Experts
