Question about Kenwood Car Audio & Video
Hello, Hi Kenwood KDC-C717 cd changer has displayed error-99. I think it may be a stuck cd. When pressing the eject button, the motor sounds, but cannot eject the 10 disc loader. Can you help? Cheers, Jon
  • jlarssen Jun 27, 2008
    Thanks for your comments. I stripped out the mechanism, seemed the motor hadn't reset it's self. I pushed it back home with my fingers, plugged it in a again & hey presto! it worked.
    Now to get those strings and funky shock absorbing gromits back home. That could be the hard part.
    Thanks alot, good work.
    Jon.
  • 4,234 Answers
The loading mechanism is either out of timing and has jammed or there is a disc that slipped out of the tray that has jammed it. In either case, the unit must be dis-assembled and rebuilt. This is not a repair I'd suggest you attempt without a service manual. The rebuild must be done in the proper order and in the corrct position in order for the timing to be correct. It is rare for parts to be required for this type of problem. Check with a local servicer for the cost to repair.
Dan
Posted on Jun 27, 2008
  • ABRsvcs Jun 27, 2008
    I forgot to add that resetting the unit is not likely to fix this. Also, the drive belt may need to be changed as well.
    Dan
    Genius:
  • 1,142 Answers
Try to reset the device
  • Maanita Chadha
    Maanita Chadha Jun 27, 2008
    Seems to be a cd stuck or it is broken inside the changer, all you need to do is take the changer out and get it opened manually which you can do it your self this will save $$$$ and its pretty easy to fix,
Kenwood 6 disc cd changer
screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
May 12, 2014 | Kenwood KDC-C465 6-Disc CD Changer
I have a kdc-c717. which players are compatible with it?
By players? do you mean DVD?
Please re-word your question to exactly what you are looking to do.
Thanks!!
Feb 17, 2010 | Kenwood KDC-C717 10-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
When I select the CD mode on the setup, Error 99 appears. there is nothing wrong with CD's inserted in the changer
The loader can not load the cd's due to a worn out plastic gear. The plastic gear drives the loader and locks it in place. Have a qualified person check it out and replace the gear.
Gerald,
Kenya
May 10, 2009 | Kenwood KDC-C717 10-Disc CD Changer
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
Need a wiring schematic KDC C717
Black typically goes to ground.
Red goes to battery (+) (+ all the time)
Yellow typically goes to switched power (+ when ignition in run position)
Mar 06, 2009 | Kenwood KDC-C717 10-Disc CD Changer
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
Kenwood KDC-C717 - E-99 error
Reset the unit ithe reset button is on the cd changer
Dec 01, 2008 | Kenwood KDC-MP205 CD Player
Car cd changer
yes. open it up and find the small motor that performs the eject process. Then turn it by hand to eject the magazine.
Jun 13, 2007 | Kenwood KAC-729S Car Audio Amplifier
Car Audio & Video Logo
176 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
