Question about Kyocera Mita KM-2530 Laser Printer
Auto paper feed jamming
Kyocera mita 2530 - auto paper feed jamming - does not happen all the time - but seems to happen more often now
  • Jimbo865 Jun 27, 2008
    thanks, I will try that.
  • Jimbo865 Jun 30, 2008
    i tried cleaning rollers with alcohol - still seem to have a problem with jamming of some paper - i haven't changed the copier paper i use - but i am seeing a problem with the lighter weight copier paper then with the higher quality bond paper. what next?
  • 45 Answers
If cleaning the ADF rollers did not help, then the next step is to have the rollers replaced. They do wear after time and will have difficulty in feeding, especially lighter weight paper. A local KyoceraMita dealer should have the parts.
Posted on Dec 03, 2009
    Problem Solver:
  • 3 Answers
Clean the rollers with alcohol. this will renew the rubber and clear up the problem
Posted on Jun 27, 2008
Kyocera mita 2530
Two most common faults for this are - if its a smudgy line, replace/repair the fuser unit. If it is a neat straight line, replace the drum unit.
Dec 06, 2013 | Office Equipment & Supplies
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
Kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
Kyocera Mita FS1010 fault
check your user guide... it will explain this error... or contact kyocera customer support...
Jun 25, 2009 | Kyocera Mita FS 1010 Laser Printer
Reset originals in processor
take the paper out of the document feeder... and put them back in... thats the part on the very top where you insert papers for copies...
Jun 11, 2009 | Kyocera Mita KM-2530 Laser Printer
Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Try changing print driver and switch emulation to kpdl auto if not already there. If this doesn't work go to properties on driver under font and switch to bit map. Don't do this step unles yo have to it really slows down your printer.
May 29, 2009 | Kyocera Mita KM-2530 Laser Printer
Error Code C2500 on a Kyocera KM-2530
a C2500 error code relates to the paper feed area.
It indicates either a faulty paper feed motor, loose plug for the motor or lubrication problem in the feed area.
Hope this helps.
Apr 24, 2009 | Kyocera Office Equipment & Supplies
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
Apr 23, 2009 | Kyocera Mita KM-2530 Laser Printer
Kyocera Mita KM-2530 Laser Printer Logo
160 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
