Question about Fujitsu LIFEBOOK C6637 PC Notebook
Fujitsu lifebook c6637
The mains adapter socket has been struggling to connect to the charger but was able to use it, now it has stopped altogether, how easy is it to mend or replace the socket? i do have another (different) model that could act as donor but i am reluctant to start taking it apart without some guidance. my skill level is average i have built several dektop and tower computers)
    Genius:
  • 2,028 Answers
The dc jack is soldered to the motherboard. You will have to tear the machine completely down in order to replace it. The link bellow has break down diagrams, you might be able to find one for your model there.
http://repair4laptop.org/notebook.html
As far as getting a jack, Ebay is a good place to get one. I get jacks for my customers from vendors there, and a couple of the vendors have compatibility list of the different machines the jack will fit.
Posted on Jun 27, 2008
I want to format loptop acer aspire one d257
go ahead , you do have my permission.
please state a question,
how?
why?
what, where, when, ? a question.
Oct 02, 2013 | Fujitsu Siemens Fujitsu Lifebook Loptop...
Battery problems
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Jan 15, 2013 | Fujitsu LifeBook C1110 Notebook
Cant play cityville
Lucky you? TBH... Check if you have admin settings... latest java/browser settings...and really... there's better to play.
Oct 18, 2012 | Fujitsu Siemens Fujitsu Lifebook Loptop...
Where is the wireless switch located on the Fujitsu Lifebook A series model AH531?
I'm not sure where the switch is but to enable the wireless connection, you could go to the control panel>network and internet, in the left hand menu choose, Change adapter settings, right click on your wireless network connection and click enable.
Mar 16, 2012 | Fujitsu LifeBook AH531
I have a fujitsu lifebook A series, Model AH531/GF0, it will not receive current from my ac adapter. The computer is total blackout. What is the main problem of said lifebook?
Please check the voltage at the pin end of the laptop using a multimeter in the voltage range. If absent then there is fault in the adapter and must be opened to confirm or replace.If present then connect and check the voltage at the pin end of the battery terminal in the laptop , if present the battery is a suspect.Check this link: http://www.fixya.com/support/r5164850-laptop_power_supply
Jan 17, 2012 | Fujitsu Computers & Internet
Shut down pc and moved to another room. When I plugged into wall, no indicators of battery charging or even that there is an outside power source. Tried new battery, lifebook shows no signs of life.
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Feb 04, 2011 | Fujitsu LifeBook A6120 Notebook
Fujitsu lifebook blinking battery led, bad ac adapter?
i would try purchasing a universal laptop charger on ebay and see if it works. they are under 25 bux. worse case scenario you will have a backup ac adapter. be careful plugging in other ac adapters because the polarity could be wrong or it could have to much amps
Jul 11, 2010 | Fujitsu LifeBook A6025 Notebook
Fujitsu nseries won't power on at all
check ur laptop battery and charger are okay. try to on it with direct adapter power if it will be on so replace ur battery
May 02, 2010 | Fujitsu LifeBook T3010D Tablet PC
P5010D does not start when pressing On/Off button
first is the ac adapter
next is the ac jack , if the pin is loose , or you have to move the adapter to get it to work, it could be bad jack
Jul 18, 2009 | Fujitsu P5010D (AWA061A90ED00422) PC...
Not picking up wireless networks
What you need to verify is that the wireless adapter is not disabled or turned off. There is a switch on the front edge of the unit that will turn the adapter off and on.
if you go to http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/S7210_GSG_B5FJ-5241-01EN-00.pdf you can see the picture of where it is, but from the center on teh front edge, where the latch is, moving to the left, is the mic socket, the headphone socket and them the on/off switch you are looking for. slide it the other way and that should get you back on.
If that doesn't turn is back on, verify in the network connections that the adapter is enabled as well.
May 18, 2009 | Fujitsu Siemens Fujitsu LifeBook S7210...
Fujitsu LIFEBOOK C6637 PC Notebook Logo
75 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
