Norcent TV Model LT2030 power supply problem
I have a fairly new 2-3 year old norcent 20 in TV.It will not power up and the tv shop says it needs a new power supply. Can I do this repair ?  Where can i order the replacement power supply?
thanks
jl
  • jimlindsey Jun 29, 2008
    i need info on where to get the part and how to do the repair. No way am I paying $250 for repair
    i'm looking for a little more specific advice advice than go to a "surplus store" for the part and go slow taking it apart
    Genius:
  • 1,665 Answers
Following comment helps on troublshooting power problems.
"If there is no voltage at the Mains smoothing capacitor then we have a fault in one of the things before it.
  1. Mains Plug
  2. Mains Lead
  3. Fuse (1at to 3.15at)
  4. On/Off power switch
  5. Filter components
  6. Surge Limiter Resistor (1.5 to 9R) big wirewound
  7. Some Circuits have a Mains Standbye transformer and a relay(See circuit at bottom of page)
3/6 If the fuse or the surge limiter has gone "
Posted on Jun 29, 2008
  • 4,472 Answers
If you need more advice then what has been provided then it is most likely you don't have the expertise to tackle this job yourself. I would recommend you just have it serviced or for 250$ you can buy a 20 inch television brand new with a warranty.
Hope you find this helpful keep me updated.
Thanks,
Lee
  • 3,037 Answers
Here are the specs for the power supply, match them up and you will be fine. Sears Parts Store will probably have one otherwise the manufacturer would, if you are having trouble getting one, let me know.
Power Power Device: Power supply
Voltage Required: AC 120/230 V ( 50/60 Hz )
Power Consumption Operational: 90 Watt
It isn't hard to replace but will require some knowledge of electronics, let me know if you need help with this when you get the part. good luck
  • 161 Answers
You can get power supplies at a fairly cheap price at surplus shops near your area. Everything in surplus is relatively cheap and relatively dependable. As for installation, that will depend entirely on you, how well you can replace and reconnect wires as needed. You'll have to open it real slowly and carefully, making sure not to force anything out of place. Steady as she goes. You shouldn't need much equipment, a soldering kit will do fine with a pair of pliers and perhaps a small range of screw drivers. Keep your distance when plugging it back in after you've fixed it, just to be safe. :) let me know how it goes.
  • john yray
    john yray Jul 11, 2008
    Bro you'll probably get electricuted if you attempt to do something you no experience with. I take back what I said, because I refuse to put your life in danger. Paying 250 won't be as bad as paying for any potential damages that may occur if you reconnect some wires improperly, which could start a fire or a small explosion.
  • 1,879 Answers
Greetings,
If you know electronic stuff, check out the power supply section.
Replacing the power supply is another story, it is not just like swapping cartridge (soldering stuffs will be needed).
Have them replace the power supply, it is worth the hassle.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 28, 2008
No power, no blinking lights for my panasonic th-42px60u TV. I bought my TV new about 7 years ago. I have had no problems with it until today. I was watching a program I heard the click I normally...
the power supply inside the tv, is what it sounds like to me. I fixed a 50 plasma about a year ago that all it needed was a 20 cent capacitor. but you might find the power supply for yours on ebay for kit 20 bucks or a used board about 50. this is not a for-sure fix, but if you can fix it saves you about $300+ just be careful when working on it you dont crack the screen.
the one I fixed was a first generation plasma flat screen tv and it price was about 10 grand. I love it it still works good and has a nice picture.I have the most expensive TV on the block ! it likes it's power though 500 watts .
So in summery, the two things I have found over the years in my "look what I found honey" tv projects is that the power supply has failed or the screen light driver needs to be replaced. in the last 30 years I have only purchased 2 new TV's and fixed and gave away to friends about a 100. and that was before I had internet and parts had to be hunted down by catalogs and phone,
SO go ahead and try fixing it, if you cant fix it Give it to your local TV repair shop for parts, he might help you out in the future if you need parts, to fix another stray you bring home ?
Jay... The Pool Pump Repair Guy in Longwood Florida 32750
Feb 08, 2014 | Panasonic TH-42PX60U Television
T.v. will not come on model LT 2327
This is either a power supply problem, or, as I suspect, the capacitors are blown out on yuour screen. Alot of screens nowdays are having this problem, as they come with capacitors to energize the screen, and the capacitors are coming from China and Taiwan, with low quality standards. The caps should last between 15-20 years before going out, but on alot of these tv's the caps are burning out in about 18 months to 2 years. If your tv is still under warranty follow the warranty instructions for repair, if it has no warranty, or if it has expired, then take it to BestBuy or Fry's electronics. They both have special technicians for this type of service. Just Know that it is not cheap, as the repairs can sometimes cpst as much or more than the cost of a new TV.
Dec 17, 2010 | Norcent Technologies LT-2723 Television
Is there a web site that would walk me through removing the power supply board in my 42" Norcent LCD tv?
Very easy to replaced the power supply board.Just take the tv aparts.Use a Philip screw driver take out about 6 philip screws and take out all the board connections to take out the power supply board.Just do the reverse to install the refurbish power supply board that u bought.U can try You Tube,might have video turtoring replacing boards.
Apr 26, 2010 | Norcent Technologies LT-2020 20 in. LCD...
My norcent 20' lcd tv lt-2022 wont turn on. light flashes.
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 18, 2009 | Norcent Technologies LT-2022 20 in....
Sound no picture
Most likely the TV has a power supply related problem. The most common problem are the power supply for the screen itself. Most manufactures call it a Backlight Inverter Board. Something you may want to look at for your problem. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
Sep 18, 2009 | Samsung SPN4235 42 in. Plasma HDTV
TV is dead. No standby light, no power light. We left for the day with the tv turned off and 6 hours later we found the tv dead. Any ideas would be greatly appreciated. The tv is about 2 years old.
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, something simple like a blown fuse inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
1. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 09, 2009 | Sylvania 6626LCT 26 in. LCD Television
Standby light is onand tv will not turn on
I just got off the phone with what used to be Norcent....they are no longer in business, and do not know how or when they may be able to provide support to those of us that spent our hard-earned money on the garbage they sell. I have a LT 3222 and it lasted alittle over a year, not the picture is red and white. I called today to try to get some troubleshooting advise on the unit...only to be told that they went out of business last week. Sorry I did not have more info
Sep 19, 2008 | Norcent Technologies LT-2723 Television
LCD TV Remote quit working
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
support@norcent.net
Mar 24, 2008 | Norcent Technologies LT-2722 27 in. LCD...
TV making chirping sound
If one of the secondary supplies is shorted, the power supply will "chirp" when plugged in. This is the power supply's way of protecting itself and this usually happens when the horizontal output transistor is shorted. If this set was in my shop and needed a new output transistor, a fair price would be right around $100.
Jun 28, 2007 | Toshiba 32DF46 32" TV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Electro Med Services...
