My t.v one day just expanded wide screen and there is no options on the t.v to fix it, we have a rogers box if that is any help but there is no options on it eaither that work
Reset the TV back to default settings. Unplug TV for 5 min. Hold down the power button for 10 seconds. Reconnect the TV. Power it back on.
Posted on Jul 05, 2008
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Chunghop rm 306e
you must the buttom ZOOM, for to wide screen.
the 16.9 is the normal screen.
God bless you
Jul 30, 2013 | Televison & Video
The image is too wide
It would be helpful if I knew what else you had in the setup. Mostly I just need to know if you have a cable box, I will assume this is the case.
I had this problem with my Tv, if it running through a Bose system the problem is most likely with the Bose system, you need to go into the options and go to picture and select Full Screen instead of widescreen.
If you are not using a Bose system then the problem is still fairly simple.
  • Look at your remote for the Tv, locate the menu button and press it. A menu should come up.
  • There should be a video or screen option in the menu select it.
  • There should now be a wide variety of options to choose. Choose the normal option.
  • Then close the menu the video should now fit the screen.
If this doesn't work then it be your cable box, to fix that you follow the same steps just using your cable box remote instead of the Tv remote.
If this doesn't work comment and I will see if I can figure out another problem.
Hope this helps.
Chengeaj
Mar 07, 2011 | Toshiba Regza 42RV535U 42 in. LCD HDTV
How do I see the hole picture on my Philips match lll line. Black corridors on each side cuts away the sides of the picture. /t
You may actually be looking at the entire picture. The newer televisions have a 16:9 aspect ratio (16 units wide for every 9 units high). The older sets had a 4:3 aspect ration, and a lot of material was made for the 4:3 screens. There are three ways to look at this material on a wide screen set: use the "shadow box" you describe, stretch the picture sideways to fit the screen, or expand it to fit width and lose the top and bottom of the picture. Your choice depends on the material and your personal preference.
Now, if you know you are looking at wide screen material, you need to correct a setting in the view format options. These settings go by various names in the instruction manual and on-screen menus - "resolution", "aspect", or "display format" are common. I haven't seen the menus on a Phillips set, so I don't know what term they use.
Oct 24, 2010 | Televison & Video
The screen is wider than the screen on my tv. tv screen to view is expanded like for a wide screen tv
There should be a format button on your remote control. If your using a satellite receiver or a cable box the format button might be on that remote.
Mar 01, 2010 | Televison & Video
When i expand tv to wide screen I cannot see lower-Dynex 32" lcd
Is your sky or dvd box setup in 16.9 wide mode, same goes for your tv.
You should have a aspect ratio button on your remote, what equipment do you have?
Sep 18, 2009 | Televison & Video
How do you adjust screen size in HMDI mode screen display is centered and not wide screen
That is one big problem with the Vizio, They do not have this option. You may have better luck trying to adjust it through your cable box if you have one. They do offer an option on some of there remotes that says "wide" this will magnify the picture to full screen in most cases, it has been the only solution I have been able to find, besides the setup on the cable box. I hope this helps, Good luck.
Jul 23, 2009 | Vizio VP322 32 in. Plasma TV
Changing picture to wide screen full screen on Samsung HPS4253
I just had my digital cable installed yesterday. He had to jack with it for about 20 minutes until he got it to work. He accessed some sort of internal menu on the cable box by pushing power and menu at the same time. He had to select some sort of 4:3 overide option and that finnaly did it.
Aug 31, 2008 | Samsung HP-S4253 Television
I need UNLOCK CODES
Reasons to unlock your Rogers device
  • Use phones exclusive to Rogers with other GSM network carriers around the world.
  • The freedom to chose any carrier you to use with your Rogers locked device by simply swapping SIM Cards. No more SIM Restrictions!
  • Increase the resale value of your unlocked Rogers device
http://www.unlockallcellular.com/
Nov 28, 2007 | Nokia 6233 Cellular Phone
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
