Question about LG Shine KE970 Cellular Phone
Not synching my pc only recognises phone as storage device but will not synch. i want to transfer my contacts but nothing is happening help!!
Yes i found a solution. Basically my pc was not installing the CD properly and i think it would leave out some files that i needed to run the software fully.I decided therefore to download the drivers. and hey presto! Until now now problem.
Posted on Jul 04, 2008
How to sync tablet with laptop
You are probably talking about synching music, photos, etc and not operating system apps which cannot be synched.
You will need your USB cable to connect the Android to your laptop's USB -2 port. You might also need drivers (software that communicates between devices) but probably not as most Androids automatically transfer those that are needed when the USB cable is plugged in for the first time.
Then you can use your laptop's file manager to transfer, copy, arrange, etc. files and folders from your laptop to your Android.
If it has an external SD card in a slot it's best to put all your music, pictures, videos there as if you copy them to the internal device storage you could fill it up fast. It's sort of a manual way to synch. Unless you can find some software to do it automatically, this is your only real option but it it's not hard at all as long as you know how to use your laptop's file manager.
May 02, 2015 | Nextbook Premium 8 Se Android
How to transfer contacts from iphone to pc?
I had a nokia E71 and downloaded software from the NOKIA WEBSITE. you can use it to transfer your nokia contacts into windows contacts.
Then you have to download Itunes from APPLE and use CLOUD SYNCH to send your windows contacts (which would have your nokia contacts intergrated) to your iphone. I used the charger and plugged into the USB of the computer for both. its alot of work but possible - and faster than manual re-enter.
note: some contacts on my nokia for example if a phone number description was changed from "work" or "home" to lets say "work cell" windows contacts did not understand custom categories and some numbers did not transfer correctly, eg, "work cell" became "fax" or nothing at all. There was some editing within windows contacts to correct the issue so that Itunes would interpret the contacts correctly.
In short:
-Nokia software
synch contacts to windows contacts
-windows contacts
check everything looks good
-itunes & cloud synch software
import windows contacts and synch phone.
(Cloud synch may be a separate download)
as far is I know there is not an easier way.
Dec 14, 2012 | Apple iPhone Smartphone
Ipod touch will not connect with xpwindows computero
Make sure you have the latest Itunes version installed.
http://www.apple.com/itunes/
Nov 26, 2011 | Apple iPod touch
My Ipod Nano Chromatic was synched to another library. Now I'm trying to synch it to a new one. Everytime I hit Transfer purchases, nothing happens. How do I transfer the songs on my ipod into the new...
You need to authorize your new library.
Open iTunes, click "Store," then "Authorize Computer." Then type in your iTunes username and password, there ya' go!
hope this helps!
Nov 23, 2009 | Apple iPod nano MP3 Player
Palm TX won't synch with Vista
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Apr 16, 2009 | Intel Palm Tx Handheld
On my Dash, when I synch, I want the dash to be master, not PC
hi.my phone is bestel D5000.my messages in box always empty.plese help me.and tel me how can format and reinstall my phone data(software).give ne best help.
Feb 02, 2009 | T-Mobile Dash Smartphone
Can't synch, only connects as guest
I have had this happen to me at work. You need to backup your Jornada on the computer that works to sync (VERY IMPORTANT) and then hard reset the Jornada (which wipes it clean). Make sure that you put the name back into the Jornada identification (it will be wiped out by the hard reset). Then try to synch on the computer that can't synch except as Guest now. It should sync fine. Then you will need to sync on the computer that works to sync to restore the backup file. Then you will be back to normal. It is a pain. I don't know why it happens but I know this solution worked for me. Let us know if it works for you.
Sep 12, 2005 | HP Jornada 568 Pocket PC
How do I get the hotsync to sync everytime there is a change?
You may be used to PocketPC ActiveSync. HotSync is an asynchronous synch model - you synch upon demand but not continuously. Pocket PC devices synch all the time while in the cradle. There are advantages to both models. If you want to synch a Palm OS device, you need to press the button. There are some extra appliactions available on www.palmgear.com that will force your device to synch upon a schdule.
Sep 12, 2005 | Palm Treo 600 Handheld
Activesync Problem, Help Pls
Try the following. FIRST & FOREMOST BACKUP YOUR DEVICE TO A "CF CARD" USING THE BUILT IN "CardBackup" UTILITY. This is a much faster option than using ActiveSynch. It ca restore also much faster. Once your files have synched go to options & change the synch options to manual & file conversions to NONE. Remove or switch off the device. Next delete the partnership WITHOUT DELETING THE SYNCH FOLDER !!! Be very careful. Switch on or replace the device on the cradle. Active synch should recognise the device & offer to setup the partnership. Let it do so with "THIS COMPUTER ONLY" option. Once your device is scanned by activesynch one of the options it will offer is of combining the records. Select it & let it synch. I most cases this should solve the problem. Hope this helps.
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
E-125 Getting attachments for emails
What can & cannot be downloaded will be determined by your setup in ActiveSynch on the desktop. When connected right click on the Inbox on ActiveSynch main screen & select settings. Check mark the "Include File Attachments". If you are downloading the jpg files uncheck the "Limit Attachment size to" so complete attachments will be downloaded. On the PDA start the inbox, tap on Tools - Options - Storage. You should get the option of saving the attachments on storage card if one is available to save on main memory usage. But this might not be an option if you use a CF wireless ethernet card for connecting & Synching. If it does show up you will have to uncheck this option to save the attachments in main memory. Hope this helps.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
LG Shine KE970 Cellular Phone Logo
21 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
