Question about Brother IntelliFAX 4100 Laser Fax
Disable sleep mode
Is it possible to disable the sleep mode completely?
  • 148 Answers
To change the sleep mode: Press Menu Numbers 1, 8. From your key pad select the amount of time before the fax goes to sleep. 0 - 99 Press Set Press Stop/Exit You can find the user manual here for the future if you would like: http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000082/FAX4100_US_UG_0.pdf Hope that helps... Lbcoaster
Posted on Jun 27, 2008
  • swhite839 Aug 21, 2010
    Your advice doesn't address the problem of DISABLING the sleep mode, only of setting it to the maximum of 99 minutes. I've found it annoying myself and have tried everything, and was hoping to find a solution here. But, alas, not so much. Thanks anyway!
How to disable sleep mode
You enable / disable sleep mode in the power settings
Aug 03, 2016 | Computers & Internet
Tip
PC sleep mode problem?
Follow this instructions to disable sleep mode
In windows XP
1)Right-click the desktop, and select "Properties."
2)Click the "Screen Saver" tab, and click the "Power"
button at the bottom.
3)Change the option next to "System Standby" to
"Never" for either "Plugged in" or "Running on
batteries" or both if that is what you want. Click
"Apply," "Okay" and "Okay" once again to close the
Display Properties dialog.
In windows vista
1)Click the "Start" menu, and then click the Control
Panel.
2)Click "System and Maintenance," and then select
"Power Options."
3)Select "High Performance" to disable the overall sleep
mode. The monitor will still go into sleep mode unless
you click "Change Plan Settings" and disable all sleep
options.
In windows 7
1)Click "Start," and then select "Control Panel."
2)Double-click "Power Options."
3)Select "High Performance" under "Additional Plans,"
and then click "Change Plan Settings." Change all of the
options to say "Never."
on Dec 17, 2010 | Computers & Internet
How to disable the sleep mode of my msi
Hi Tyrell,
Please try to check this website on how to disable sleep mode on your machine.
1. please unplug your notebook from A/C power and remove the Battery for a few minutes and then re-test? If won't work please check the sites below.
How Do Stop My Laptop From Going Into Sleep Mode eHow
How To Enable or Disable the Standby Mode
May 08, 2014 | MSI "MS-U135DX-1679ZA 10"" Netbook, 10""...
Disable sleep mode
I believe you can in the scan validation tool. I Think in devices section. Reduce the time on the "timeout" tab. There may be a similar setting in the KodakPro softare
Mar 18, 2014 | Kodak i660 Scanner
Disable sleep mode
You have to actually go in to it and do a system diagnostic on it, or the instructions to how should be in the manual located usually in glove box.
Sep 13, 2013 | Mazda Cars & Trucks
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
My computer is going into sleep or hibernation mode while I am online, will reopen when I move mouse, but sometimes shuts off completely.
dear friend,
Have you checked the bios settings you may be able to disable the sleep mode
hope this will do
enjoy & cheers
Jan 15, 2011 | Atto ExpressStripe for Mac OSX Controller...
Disable sleep mode for HP w1707 LCD minitor
Read -> this <-guide on how to disable sleep mode/hibernation
Aug 14, 2009 | HP W1707 LCD Monitor
Sleep mode will not disable, even when send button pushed, paper put in for fax or receiver taken off hook. Sleep mode set to default 5 minutes.
Press Menu 1,8
then set minutes to 00
press Stop/Exit
This should disable Sleep mode. Please post back with any questions or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Mar 19, 2008 | Computers & Internet
Brother IntelliFAX 4100 Laser Fax Logo
1,834 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
