Question about Maytag M7Y15F2A Air Conditioner
Maytag A/C window unit
Not sure what the model # is, but it is a window unit. Was working and then just quit, like it has no power. Then a few days later, it started working again, and then last night, it quit again. I checked the breaker and all is fine there, but it just doesnt have any power. Is there a reset button or what do I need to do to get it working again?
Thanks
  • Anonymous Sep 06, 2008
    Went to bed the unit was working fine woke up the unit was off thought my wife turned it off she said she didn't, I checked the outlet and there was power. It happened once before but it shortly resetted itself I have it plugged in and its been over 12 hrs and nothing.
    Novelist:
  • 121 Answers
Check all of the connections at the outlet. If everything looks ok test the outlet that it is plugged into with a tester. They can be picked up at most stores for around 8 dollars. If you dont have a tester you can just plug in another device that you have into the outlet and see if it turns on. If everything checks out OK then there is an issue with the A/C unit. It could be alot of different things. My recommendation to you is if it is under warranty contact Maytag and send it in for service. If it is not under warranty you can either contact Maytag and send it in for service or you can call a local heating and cooling shop and see if they can service it for you. Keep me posted - Tech101
Posted on Jun 27, 2008
My stackable unit quit filling with water. It still spins and drains. I have cleaned the screens out for the water hoses. I have unplugged it for a few. What else can I do to fix my washer?
Use a meter to test the water valve solenoid coils, make sure nobody turned the supply hoses off without you knowing. Did you recently replace the fill hoses or have work done on the machine? Maytag Washer Dryer Combo Water Inlet Valve WP22001274
Jul 29, 2016 | Maytag LSE7806A Top Load Stacked...
My Maytag model number MEY18F7E will turn on for about 10 seconds then quit and trip the breaker. It just started doing this about a week ago. Has been working fine since I purchased the home several years...
Sounds like you have a bad compressor, something is either shorted out, or drawing too much power causing your breaker to trip.
Is this a window unit, or a ductless unit?
Aug 23, 2013 | Maytag Heating & Cooling
MY FRIDGE PART QUITS WORKING SOMETIMES AND WHEN IT DOES WORK IT GETS VERY COLD
HI.I WOULD TRY DEFROSTING ALL FIRST TO RULE OUT ICE BUILD UP JAMMING THE WINDOW FLAPPS.MAKE SURE IS ALL FREE.FAILING THAT U'LL NEED AN ENGINEER.TO CHECK THE UNIT AND BOARD.HOPE THIS HELPS ALI
Jul 12, 2012 | Maytag Refrigerators
Refridgerator will not cool. Freezer works fine. Noticed a pool of water on floor then started to cool again. after a few days quit cooling.
Check the water drain hole in bottom of unit. If plugged water cannot get to catch and pan and evaporate with the heating element.
Aug 25, 2011 | Maytag MZD2766GES Side by Side...
Maytag dryer on the blink.
Kindly provide few more details :-
1. Make and model of the unit?
2. How old the unit is?
3. Disconnect the power supply for few minutes, say 15 minutes and then turn it on. Does it help to resolve the problem?
4. Which light is blinking?
5. Does any button respond when pushed?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!
Dec 04, 2010 | Kitchen Ranges
My maytag air conditioner is great, quiet and cool, but it leaks
Is the unit tipped backward toward the outside of the structure? Also, check the drain holes in the drip pan to be sure they are not clogged. The holes will be under the outside part of the unit.
Jul 17, 2010 | Maytag M6Q10F2A Air Conditioner
The icemaker on my Maytag Refrigerator MFD2560HES bottom freezer with French Doors has not made any ice for about two weeks. Before this, it would go for a few days and not make ice and just when I was...
Mine (same model) does the same thing. The only way I get it to work is to open the freezer, and move the metal ice lever arm up and back down again. Then it starts. But after a day, the arm stops moving and it breaks. I can't stand it anymore.
Before moving into my new house with the mfd2560hes, I had to replace an ice maker in my whirlpool refrigerator. So, I guess I'll be googling this maytag model and buying an icemaker motor replacement kit.
if I'm successfull, I'll post it here.
May 03, 2010 | Maytag MFD2560HES Bottom Freezer French...
Oven will not light
If your oven has an ignitor then this "Tip" is exactly what you need. I would have checkked on that but you did not give a model number..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Jan 01, 2010 | Maytag Kitchen Ranges
Fridge is not holding proper temp but freezer is still working
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
The timer can also be called an advance defrost control.
Also make sure to check the heater coil for resistance. If that is open then it is the problem.
By doing a search for "appliance parts" you can find the part you eed easily.
Enter the model number of your unit and then select the part you need from the parts menu.
You will have it in a few days.
It is best to check a couple of sites to be sure you get the best price.
Heatman101
Dec 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag M7Y15F2A Air Conditioner Logo
267 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
