Question about Black & Decker BL5000 ProBlend Work Top Blender
Am looking at blad for my blender the modle number is BL5000
  • 3 Answers
Bl 5000 replace support ring
e-mail the manufactor maybe they have some.
Jan 31, 2013 | Black & Decker BL5000 ProBlend Work Top...
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Unit began smoking and smelled hot
If this was a recent purchase for which you have a receipt, return it to the store immediately while you still can. If it is beyond the store's return policy, but purchased less than one year ago (most times you will still need a receipt), call Black and Decker to get in-warranty service/replacement.
In fact, call Black and Decker anyways - if the BL5000 was manufactured between Dec.2003 and Jan.2005 (highly possible if it was marked on clearance), the blade assemblies were recalled. here is the recall notice:
http://www.blackanddeckerappliances.net/safetyrecall2.html
If it is out of warranty, let the blender cool for an hour. Then remove the blender jar, plug in the base, and see if it will spin with nothing attached to it. See if it smokes if left on for 1 full minute - don't let it run longer than one minute.
If it doesn't smoke, let it cool for an additional 20 minutes. Then remove and then reassemble the blade assembly, gasket, etc., collar, jar, etc. Try blending. If it smokes while blending, order a new blade assembly and gasket (usually they come packaged together - around $20 or so). Once the new blade assembly/gasket arrives, try blending again. If it doesn't smoke, you're probably good to go. If it does smoke, you have a more serious issue.
All of this is going to take time and money if it is out-of-warranty. If you have deemed that the blender is worth more than $50 for a new one, let me know.
Mar 26, 2009 | Black & Decker BL5000 ProBlend Work Top...
Black and Decker BL3900 stopped working
I had the same problem with BL6000 model. After using the blender few times it went dead, though on occasions it ran for a couple of seconds or so. I opened the base and saw the red light come on and off in response to pressing the buttons, but the blender would not run. I checked the connections and resistances across various points, and then decided to bypass the digital control panel by joining the blue (AC) and black (motor) wire terminals, as the control panel must be altering the frequency or voltage going across this connection into the field coils (and also to rotor). The motor is rated at 120V. The motor ran perfectly, though i let it run only briefly, confirming that it itself is all right. I think one must check a step further by studying the current and voltage characteristics to ensure that the motor does not consume more than rated 550 watts if you do not wish to buy the digital control panel ( part number BL5000-01-01, available through partstore.com or black and decker partner site. It should fit BL6000 as per partstore.com). The motor seems like an univeral motor. If anyone knows more about motors and has the same problem, then pl let me know if bypassing the digital control panel and using an external switch to shut the motor on and off is a good idea (digital panel and shipping will buy an equivalent blender in stores, about $18). I am afraid that if digital control panel does not let unregulated power be delivered to the field (and rotor) coils, then one may be putting too much power into the motor and it may burn out prematurely.
Oct 15, 2008 | Black & Decker BL5000 ProBlend Work Top...
Broken Glass Canister
Sure there is. You can get it from Fox International. Here's the link.
http://estore.fox-international.com/accessories.asp?modelnumber=1338
Good luck.
Tracy
Aug 05, 2008 | Black & Decker BL5000 ProBlend Work Top...
I had to call Black and Decker directly 800-231-9786 to order the part (called the "collar"). It was $14.95 w/ shipping and handling!! Seems pretty steep for a piece of plastic.
May 04, 2008 | Black & Decker BL5900 ProBlend Work Top...
Buttons click but it won't run.
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask, strawsj1234@hotmail.com
Mar 17, 2008 | Black & Decker BL5000 ProBlend Work Top...
5 speed ...steel
Sep 11, 2007 | Black & Decker BL5000 ProBlend Work Top...
Stopped working
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask.
Sep 01, 2007 | Black & Decker BL5000 ProBlend Work Top...
Black & Decker BL5000 ProBlend Work Top Blender Logo
155 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
