Question about Dell 3300MP Multimedia Projector
Resetting lamp How do I reset the lamp? I don't have a manual so I'm not sure how to access the main menu you referenced. thank you
In the menu goto managment and then lamp reset
Posted on Jul 03, 2008
How do you reset lamp timer
This is usually accessed from the projector's main menu. Use your remote by pressing 'MENU'. Navigate around each menu option until you find something referring to 'RESET'. (ie: reset lamp, reset, reset to zero)
No remote? - You'd have to use the onboard projector buttons.
Jul 15, 2014 | Vidikron Office Equipment & Supplies
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
I don't know what happened but ipod does nothing. tried resetting (menu & select)(menu/select & select/play) not sure what else to do. plugged into computer and still nothing. please help
Welcome to Fixya
Try resetting the ipod by pressing the middle button and the menu button at the same time for 5 to 10 seconds. The ipod logo should appear after the reset has done.
Thank you for using FIxya!
Oct 02, 2011 | Apple iPod classic MP3 Player
Sony Cyber-shot DSC-T7. Pressing Menu button does not access any menu. Can only access Image Size menu by pressing Image Size/Delete button.
I'm sorry that the Menu button on the Camera is not working. Please try a power resetting and check the operation:
To perform the power resetting, remove the battery, press and hold the power button for more than 5 seconds and then reinsert the battery.
If the issue persists after resetting, service may be required. Please click hear to locate your nearest service facility.
Thanks for understanding. Please let me know if you require further assistance.
Jun 19, 2011 | Sony DSC-T7 Digital Camera
Why does the projector keep going to standby mode?
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Mar 12, 2011 | Panasonic PT-AX100U-EC DLP Projector
What will I do to reset lamp timer for my Panasonic PT-AX200 model
Read very carefully this is the only solution to reset lamp timer
1. Connect the mains lead to the projector and a mains socket, and switch the MAIN POWER on. 2. Press the POWER button.
3. Press the MENU button to display the menu.
4. Select the OPTION menu and press the ENTER button.
6. Press and hold the ENTER button for approximately 3 seconds.
7. The confirmation screen will be displayed and select OK.
8. Press the POWER button to turn off for resetting the duration of the LAMP RUNTIME.
9. Next time when you POWER ON the projector the duration of time in LAMP RUNTIME is reset to "0 H".
Jan 06, 2011 | Panasonic PT-AX200 LCD Projector
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Hi Greg147
The resetting is not done in the menu.
Plug in your power cable - Machine is now in standby mode.
Then Hold down the left and right arrow keys on the Projector and press the power button. You'll see a indicator light on top of the Projector flashing twice - Lamp hours is now reset.
Hope this is of help.
Apr 01, 2008 | Mitsubishi ColorView XL30U Multimedia...
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Dell 3300MP Multimedia Projector Logo
331 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
