Question about Sub-Zero 661/F Side by Side Refrigerator
Sub-zero Refrigerator Door
I have a sub zero refrigerator and the door won't close tight. someone said that the rubber tubing around the door is worn out and something about magnets inside the tubing not working? don't know much about these things. Can you tell me how to fix this? Thanks, Don
  • 2 more comments
  • katcox Jul 07, 2008
    We have the same problem 'The door doesn't seal properly. We have replaced the gasket and and a bar near the hinge on the bottom of the door. Neither of these things have solved the problem.
  • careywendy Jan 02, 2009
    My sub zero has the same poblem...it's so annoying. The temp inside the frige now is 64! I have to flip the circuit, wait 5 minutes, turn the system back on and pray. I'm sick of it!!!!
  • lucy Sep 15, 2012
    I have the same problem with the seal on my sub-zero. Thanks. I moved items from the door and it sounded and felt like it shut.
  • Anonymous Mar 21, 2014
    door will not close on it's own
    Habit-Forming:
  • 41 Answers
Song to me door gasket was not properly installed, We using electric steamers to make rubber softer and good sticking. Right after door seal was replaced. Also, it could be that: a bottom door hinge parts broken /little white plastic cams damaged/,or, fridge not leveled or too heavy load on door shelfs.
________________________________________________
http://www.subzerolosangeles.com
Posted on Aug 04, 2008
We have the same problem and were told to apply vaseline to the rubber edges of the door; this did help.
Posted on Sep 27, 2008
Sub zero refrigerators 632 door won't stay closed
Thee is a plastic cam at the bottom hinge of the door. Mine cracked and I bought a new one online for like $30 (for a piece of plastic). Got a strong friend to lift the door off the hinges while I replaced it. make sure you get the right one for left or right doors.
7014663 Sub Zero Refrigerator Bottom Cabinet Hinge Cam LH (7014663) (7014663) - Genuine Refrigerator Parts
Sep 01, 2014 | Sub-Zero 632 / S
Sub-zero refrigerator on but not cooling
thats right, if compressor running you most likely have to go thru this repair.
Jul 21, 2014 | Sub-Zero 601R
Why does subzero refrigerator door closes tight
It's a big door. You should check the refr drain. If that's blocked it will be harder to open than normal.
Jul 13, 2014 | Sub-Zero Bottom Freezer Refrigerator
Door slow closing sub zero 650
The door cams are worn under that door, this unit takes two, one for the door, the other for the hinge. They are different too.
Good Luck
Jan 30, 2013 | Sub-Zero 650 / O Bottom Freezer...
The frdge door does not close on its own
before any test clean the seal around the door and refrigerator with warm soap and water.
you may have a seal problem, check around the door, make sure the seal is intact. check for tears,
liquid, a pinched seal. take a sheet of paper and put it in between the door and refrigerator while
holding the door closed. check all around the door, if you can pull the sheet out without any
hesitation that's where your seal is broken. good luck!
May 26, 2011 | Sub-Zero 661/F Side by Side Refrigerator
My sub zero refrigerator makes a gurgling sound when you close the refrigerator door - sound is coming from the side of the unit.
Hi this is the drain tube sucking water back up through, this is caused by the vacuum inside the refrigerator that is formed when the air condenses, not much you can do about this sound its fairly normal.
Sean
Apr 01, 2011 | Sub-Zero 650 / O Bottom Freezer...
Closing and opening a sub zero door
Maybe I'm not understanding your question completely.. You can open the doors whenever you want - as often as you like. The doors are no different than any other fridge as far as how often you can open and close them. Please clarify if I missed your intent. Thanks!
Jun 17, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Ice making for sub zero 48
The sub zero should make ice soon after being installed. If there is ice around the door frame of the freezer there may be a problem with the door frame heaters. There should not be ice around the door frame.
Nov 09, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero 695s - plastic/rubber fridge door edge is warm
This is normal and is to keep door from getting moisture or sticking around door seal. You also can contact them at 1-800-222-7820
Sea Breeze
Mar 27, 2009 | Sub-Zero 695/O Side by Side Refrigerator
Sub-Zero 661/F Side by Side Refrigerator Logo
1,806 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ACME Sub Zero...
ACME Sub Zero...
Gere knutson
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
