Question about AOC LM729 17" LCD Monitor
Crt monitor problem
I have a 17inch CRT monitor. My problem is that the display becomes smaller (horizontally) than the actual size. Any suggestions will be greatly appreciated.
My monitor is a philips 15". It shrinks horizonally suddenly and after a few minutes it comes to normal.
Posted on Oct 02, 2008
Try to check the pincusion...
Posted on Jun 28, 2008
Crt monitor height are coming very small in size picture wat probelm
Did you set ur resolution screen setting higher than 1024 in ur computer panel resosulion setting?Yes than that is ur problems right there.CRT monitors modes are based on old technologies ,CRT monitors can't go up more than 1024 resolution setting.Setting resolution more than 1024 resolution for CRT models monitors will have thesse causes.The screen resolution on the screen will shrink and get smaller or will not have video resolution on the CRT monitors screens at all.Only LCD or LED monitors models can support and go higher than 1024 resolution setting has none of these causes.Time to upgrade for a new monitors technologies like LCD or LED monitors models.
Oct 17, 2012 | Computers & Internet
My lg 17inch CRT flatron E700SH monitor is blinking light but it not given display
Did you check to make sure the PC is sending a video signal? Try another screen to confirm if possible...
Oct 22, 2010 | LG Studioworks 700S 17" CRT Monitor
LG 700B SHAPE SIZE AND POSITION UPSET PLEASE HELP TO RESTORE
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
Samsung CRT monitor Horizontal width control
unfortunately there is really no way to fix that what happened is that the crt is no longer responding to the menu best bet would to purchase another one.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Pincushion and Horital Size Problems
This is a hardware based issue, and sadly cannot be fixed without sending it to a service center. If you really want to, you can send this monitor to a service center, but it will be around 100 bucks to fix. I would say just replace it with a smaller LCD panel. They can be bought for around the same price, and they'll save power too.
Feb 05, 2009 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Hai i have a problem in my 17inch samsung CRT monitor
hello ramesh here.
i hope you should try in lajpat rai market in new delhi. and it would be approx 800- 1000.
you did not maintain that where you live.
thanks
bye
Nov 13, 2008 | Samsung 21" FLAT CRT COLOR MONITOR
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor makes annoying screech noise
Hello.
What you are reporting is a problem in the horizontal section of your CRT monitor. Usually this is from a component that is failing in the Horizontal circuit.
Most CRT monitors use what is called scan rectification to develop the voltages required for the different circuits inside the monitor. This puts a strain on the Horizontal Output circuits that are responsible for not only the voltage to the flyback transformer to allow CRT illumination (40,000 or so volts DC), but some of the flyback secondary power circuits are what runs the rest of the monitor. When the components in the Horizontal output circuit get weak and can no longer support the higher demands of the dependant circuits, the flyback transformer tries to run harder. The more current it tries to draw to continue operating, the louder the whine becomes. Since the flyback operates around 17,000 cycles per second, it is in the audible range. Since you can physically hear it, you can also notice the change as the load demand on it changes.
What happens when you reduce the size of application windows or minimize them entirely is the demand on the power circuits is lessened and the flyback circuit is no longer trying to produce the higher demand that it was with the large application windows.
It is a good bet that it will not be too long before the Horizontal output and/or transformer give out completely and leave you with a dead monitor and a large repair bill.
Since it has not gone completely out yet, I would suggest you consult your local repair shop for an estimate. It may be a simple matter of replacing the high voltage capacitors around the Horizontal output transistor before the other parts in the horizontal circuit are damaged. This would certainly be a less expensive alternative.
If you opt to not get it repaired, new 17 inch LCD flat panel monitors can usually be purchased for around $150 or so.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
(I realize I probably gave you more information than you wanted, but I felt it might make things a bit easier to understand. If not, please forgive the disertation.)
I hope this helps.
Nov 06, 2007 | HP Compaq FS 7550 17" CRT Monitor
Monitor settings
Try to see if the resolution in your Operating System is not to small, Most likely the smallest for that monitor is 1280 by 1024, and see if the color quality is at 32 bit
Aug 22, 2006 | E-Machines eView 17f 17" CRT Monitor
AOC LM729 17" LCD Monitor Logo
100 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
