Question about Panasonic KX-T7431 Corded Phone
Recording away message
How can I change or record a new away message on this phone?
  • 3 Answers
Lcllaw - do you want to change an individual's greeting or a company greeting?
Posted on Jul 10, 2008
How do I change the message on my answering machine?
Which Uniden phone do you have? for some models, you access the Answering System menu from the base; on others, you need to be holding the handset. The generic steps are below.
On the appropriate part of the unit, make sure that the phone system is in standby (no active calls on any handset). Then press Menu. Use the arrow keys to find the line for Answering System. Press OK. Navigate to a line about Greeting and press OK. You should see (and select a line) for Recording message. You'll be prompted to ensure that you want to record a new message. If you are using the handset, hold the unit about 6" away from your head. After confirming that you wish to record a new message, speak your new message clearly. When you are done, press End. The unit will cut off the recording if your message was too long. Make sure to save the message. Then go back up in the Menu system and look for a line for "Play back Greeting". If the message isn't clear, start over.
I hope this helps. Please add a comment with the model number of the phone for specifics for your manual. Some DECT phone manuals are available here: http://www.uniden.com.au/australia/cs_operating_manuals_phones.asp .
Nov 21, 2015 | Uniden DECT 6.0 Cordless Phone
How do i change the message on my answering machine
Hold the announcement key down. If the old message is there it will read it out loud to you. If you wish to change it, just hold the announcement key and speak over the old message. Make sure you keep holding the announcement key as you record your new message. When you have finished recording, release the key. If you wish to hear your message push the announcement key again. Do not hold it down this time. If you are not satisfied with the new message, repeat the method by holding down the announcement key again and recording your message. Your old message will disappear once you have recorded your new one.
Jan 07, 2013 | Vtech DECT 6.0 Digital Cordless Phone
How do I change the message... we set it a few years ago...can't find book
Oops, I posted the info for this on the VTech problem below sorry.
To change the message, first make sure your phone has the correct date, time, year, am or pm, etc.
Now, to Record Greeting - if you don't record your own greeting, a pre-recorded greeting message is used.
So, try this:
1. (Menu) press
2 (Go to Answering Device" with up/down arrow, press OK
3 (Go to "Record Greeting" with up/down arrow, press OK
4 After the handset beeps, speak clearly about 20 cm (8 inches) away from the
microphone.
5 To stop recording, press (OK)
6 (OFF)
Hope this helps.
Mar 30, 2011 | AT&T DECT 6.0 Cordless Phone System with...
HI! How do I change the message on my phone?
You can record your own greeting message (max 2 mins & 30 secs). If you don't record a greeting mesage, a pre-recorded greeting message is used & asks the caller to leave a message. (Make sure your phone has the correct date, time, year, etc.)
To record a message:
1. Menu (OK) the "Answering Device" (OK), the "Record Greeting" (OK)
2. Then after the handset beeps, speak clearly about 20 cm (8 in) away from the mike.
3. To stop recording, press (OK)
4. (Off)
Mar 30, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I change the greeting message?
You can record your own greeting message (max. 2 minutes) that is played when the answering system answers a call. If you do not record a greeting message, a prerecorded greeting message is used. 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm (8 inches) away from the MIC. 4 To stop recording, press {STOP}.
Mar 08, 2011 | Panasonic KX-TG5632 Phone
My answering machine message is out dated and needs to be changed how do you do it?
Recording your greeting
message
message (max. 2 minutes). If you do not
1 {GREETING REC}
from the MIC.
Feb 11, 2011 | Panasonic KX-TG6021M Cordless Phone
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
message
message (2 minutes max.).
1 {GREETING REC}
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
Panasonic kx-tg2740 cordless phone - how to change message?
  • Step 1Begin the recording process by first locating the "Change" button on your answering machine. This button initializes the answering machine for adjustments to the settings of the various features.
  • Step 2:Locate the microphone on your answering machine and lean towards it until you are about nine inches away.
  • Step 3:Locate the "Annc" button. Press and hold the "Annc" button until it beeps. Begin recording your message.
  • Step 4:Watch the message window while you are recording your message. It keeps track of how much time has elapsed since you began recording. You can record a message that is up to three minutes long.
  • Step 5:Locate the "Stop" button and press it when you have finished recording your message. The answering machine will play your message back at this point. If you are not satisfied with your message, repeat the steps to record it again.
  • Step 6:Press "Annc" if you want to listen to your message again.
i found this i hope it helps
Jan 10, 2009 | Panasonic KX-TG2740 Cordless Phone
Samsung tocco
Can some one please ell me how to change my answer message on my tocco phone. it says im away and I really need to change it
Aug 28, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
How to record greeting message
Page 21 of the manual: http://service.us.panasonic.com/OPERMANPDF/KXTG5100M.PDF
1 Press and hold [GREETING] until
“Record greeting after the beep” is
heard.
2 After the long beep, talk clearly,
the MIC (microphone).
• The elapsed recording time is
displayed.
• If you record for over 2 minutes, the
unit will stop recording.
3 When finished, press
[GREETING] or [STOP].
• The unit will play back the recorded
greeting.
• To change the greeting, start again
from step 1.
Aug 26, 2008 | Panasonic KX-TG5100 Cordless Phone
Panasonic KX-T7431 Corded Phone Logo
209 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
