Question about Kenmore 24032\24036 Top Load Washer
KENMORE TOP LOAD WASHER
MY WASHER WON'T FILL WITH ANY WATER, THE WATER COMES ON BUT IT JUST RUNS UNTIL I CUT IT OFF?
  • 481 Answers
 disconnect the water inlet lines that attach to the back of the washer and see if the screens are full of sand. sometimes sand or dirt comes thru the water lines clogging up the screens in the washer. try to clean them without taking the screens out of the water valve.
Posted on Jun 27, 2008
Washer machine
Sounds like the hot water solenoid is stuck.
Feb 11, 2008 | Kenmore 22422 Top Load Washer
Washer over fills with water
They work on a pressure switch. It has a rubber hose that connects to the bottom of the drum and runs up to the top control panel. When water fills up into the hose the air pressure trips a switch. So either the switch is bad and not making contact when it clicks. Or the hose is leaking air so it won't let it build up enough pressure. I had one that a mouse got up into and chewed a hole in the hose. You can take the back panel off of the top control panel and let the water in and listen to see if the switch clicks when it gets fulll. If it does and doesn't stop filling then it is a switch.
Or it could be the water shutoff switch where the water hoses hook up. If it is that then it will run all the time, more than likely. Is that what it is doing? Does the washer start running and water keeps coming in? Because it wont start running until the pressure switch is enganged. If it starts running and keeps coming in it is that. Good luck hope this helps.
Dec 04, 2011 | Kenmore 24032\24036 Top Load Washer
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer
if the water was overflowing from the top of the tub it sounds like the pressure hose came loose. tilt the control panel back and you will prob see the hose that connects to the left side (where you adjust the water level) has come loose. cut about 1/4 inch off of it and re-connect it.
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
102 people viewed this question
Sal De
fordexpert
Robert Rankin
