Question about Canon PC-795 Copier
Blank Streak down left side of copy
This is an older model and we have had it for a long time. When I make a copy I get a blank streak all down the left side of the copy. Is this a toner cartridge problem or do I need to replace a drum?
  • 148 Answers
One way to tell is to take out the toner cart and shake it, reinstall and test run. If it comes out better you may be running out of toner in the cart and will need to replace it shortly. The drum and toner cart on this machine are in the same unit.
Hope that helps...
Posted on Jun 27, 2008
When I scan two-sided to pdf, the back page has a large black vertical streak down left side.
If that is the last page that has the streak use a blank page in the original scan as the last page and then the dark line wont cover the image.
Aug 19, 2016 | NEAT Office Equipment & Supplies
Blank streak down page when printing
clean the laser glass or replace the image unit for the color with the blank strip
Jan 05, 2014 | Konica Minolta Magicolor 1600W Printer
Copies have blank streak running down the middle.
Clean the optics, mirrors, lens, **** glass and platen glass. this should fix the streak problem. Hope this helps
Jul 17, 2011 | Sharp Office Equipment & Supplies
My copies have a thin blank streak about 1 inch in on the left side. the streak is about 1/4 inch wide and goes down the whole sheet of paper
Start a print or copy, and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Clean the loose toner up with a dry lint free cloth.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Brother DCP 1000 All-In-One Laser Printer
When I make copies or transmit a fax, it makes a 3/4" black line down the left side. I have cleaned ink cartridges and contacts but does not help.
The line is probably not from the ink cartridges or nozzles (assuming regular printing doesn't streak). Streaks on copies and transmitted faxes are usually due to dirt or problems on the scanner unit. First clean the flat bed of the scanne. If you have an automatic document feeder, clean that.
Clean with a lint free cloth moistened with a little water or glass cleaner. Make sure no foreign objects are in the ADF path or on the glass. For pictures see the Lexmark support site: Then enter "streak on copy" - the solution comes up in a pop up.
If the streak is shrinking, then copy a blank white piece of paper to identify where to clean further. Try scanning another page with a small mark on it. (These are particularly helpful for cleaning the ADF.)
If the mark occurs when you print, then check if you have a damaged cartridge or other ink that has spilled inside the printer.
I hope this helps.
Feb 02, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do I remove white streak from copy when i use my 3015?
Most common cause of this issue is low toner. Best solution is to remove the toner cartridge and while keeping it mostly level, shake it from side to side to level out the toner. Then re-install and test. If this fixes your issue then just be aware that the toner cartridge is starting to get low on toner.
Now if the white streak is very fine and the above procedure does not work then it is most likely something stuck to the scanner glass. To test for this print out a report from the operation panel or if you have the machine connected to a PC print something from there. Are your print outs ok? If so it means that it is definately something on the scanner glass. To locate it and clean it just make a copy of something. Now take that copy with the blank line on it and place it in the feeder just as you did with the original. now wherever the blank streak is lined up on the machine is where the spot is going to be on the scanner glass. Just open the cover where the documents go in and look for the strip of glass that runs from side to side. Your copy passes over this glass when it is scanned. Where the blank line hits this glass is where the trouble spot is. Just clean the glass with a cloth that has some glass cleaner sprayed on it. This should resolve the problem.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | HP LaserJet 3015 All-In-One Printer
Our Cannon MP 500 is leaving a 1/4" wide black streak on the back side of copies. I have cleaned off the cartridge heads, replaced the ink tanks cleaned the heads to no avail. What is the problem and how...
HI Foster,
The problem is not with the print head. Print a blank page and if you are still getting the streak. Something is probably trapped in the printer or the rollers are dirty.
Dec 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
Magicolor 2530 DL
The streaks are typically a sign of a toner drum going bad, or possibly just dirty, or even caused by the toner being low, as you have mentioned it to be. 1 way I know to 'clean' the drums is to have the printer run multiple blank pages. If your software will not allow you to print blank pages, type a single character by using this little trick, hold down the ALT key, and type 2 5 5 on the number pad in a blank text document. This will allow you to print the "blank" document, I would suggest about 10 copies. This should help for a short duration, and doesn't use any toner.
Hope this helps!
Oct 30, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
It sounds like the lamp/light is going out.  Open the top and try to make a copy and see if the light stays on the entire time.
Oct 29, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Canon PC-795 Copier Logo
143 people viewed this question
old marine
old marine
