Question about KitchenAid Dryers
NEED ADVISER FOR MY DRYER.
MODEL NO. KGYS700GQI SERIAL NO MJ1202912 10 YEARS OLD.
STARTS O.K. HOWEVER WHEN REACHES A CERTAIN TEMPERATURE EVEN THOUGH THE DRYER IS TUMBLING PROPERLY DOES NOT IGNITE AGAIN.
aLREADY CLEANED THE VENT SYSTEM.
CHENGED THE THERMAL FUSE #3392519
PLEASE WHAT OTHER PART # SHOULD I CHANGE.
  • 525 Answers
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If this doesn't help, post me back and I will do some more research to help resolve your issue.
http://www.repairclinic.com/0088_8_1.asp#Level1_14
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 27, 2008
Why does fiat punto engine fan starts very quickly?
It's thermostatically controlled when engine reaches a certain temperature it comes on until the factory settings for temperature reaches it's lowest temperature then it cuts off. It comes on fast to cool water as quickly as possible.
Jul 21, 2014 | Dryers
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
Have a whirlpool dryer, le9380xtwo, it gets hot and shuts doen, i checked the system and the system throstate, opens up, when it cools down it makes contact again, i think it is the cycling themostate to...
The cycling thermostat is supposed to shut down when it reaches a certain temperature, cool down and then make contact again when it cools down and starts the process all over again. What exactly is wrong with the dryer?
May 30, 2012 | Whirlpool Dryers
Our Whirlpool Model LGR4634JQ0 will not heat up. I took the peep hole cover off and watched as I turned the gas dryer on (high heat). The chamber heats up and glows bright orange for maybe 15-20 seconds...
You're a good detective! Gas dryers have an ignition panel (what you saw glowing bright orange) that heats until it reaches a certain temperature. This temperature will cause the gas from the pilot to ignite and the dryer will run, staying at a constant temperature and thereby drying your clothes. It sounds as it your ignition panel needs to be replaced. It is a relatively simple process if you are comfortable making repairs. If you aren't, I suggest calling a repair professional. We did this a num ber of years ago. The repair service was reasonably priced and our dryer worked for another 6 years!
Good luck. If this works, please return to Fixya and rate my advice!
Jul 31, 2011 | Whirlpool LGR4634J Gas Dryer
Kenmore series 80 gas dryer 6 yrs old will start and tumble but will not heat up
Gas dryers have an ignition panel that gets hot and when it reaches a certain temperature it causes the pilot light to ignite. It sounds as if your ignition needs to be replaced. We did this and had another 6 years from our gas dryer.
If you're handy you can probably do this replacement yourself. If you're like my spouse and me, we found a reasonably priced professional who completed it in just a few minutes.
Good luck. I hope this helps you. If it does, please come back to Fixya and rate my help!
Jul 31, 2011 | Kenmore Dryers
Maytag gas dryer flame comes on but will not stay on
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
We had ours replaced several years ago by a reasonably priced repairman. It bought us another 8 hears on our dryer!
Jul 27, 2011 | Dryers
Dryer stops mid cycle-restarts when cooled down--is it some sensor?
Good day,
Yes it's a sensor, but if you have to restart it manually after the cool down period, it is the sensor built into the motor.
That sensor measures motor temperature and current draw. It locks out the motor until it reaches normal temperature.
If it restarts on it's own, then post back with the complete model number. It would be a different problem.
Mar 09, 2010 | Kenmore Dryers
How old is my dryer it was a hand me down the model is LHE7800W1 and the serial is M11713347
The manufacture date is dtermined by the serial number on the appliance. The following link explains how to determine the date code from the serial number on a Whirlpool:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The second digit represents the YEAR of manufacure. The first two numbers after that represent the WEEK. So...according to the serial number you provide, this dryer was manufactured the first week in May of 1981. That would make your dryer almost 29 years old.
FYI: Even though the dryer is old, many of the parts are still used in modern appliances today, so parts are still available. Whirlpool did not change their parts too much over the years. I found a parts listing for this dryer available at pcappliancerepair.com. I hope you find this information helpful.
Feb 20, 2010 | Dryers
The flash starts to charge, never reaches full charge but I hear a 'click' inside the body and charging begins again.
Sounds like you have problem with the charge storage capacitor arcing when it reaches a certain voltage. This could be due to dampness or a exposed wire or even a bad capacitor. The voltages are high so be careful if you take it apart. Try drying it in the sun or with a hair dryer.
Dec 15, 2009 | Cameras
Dryers Logo
63 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
