Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
GE washing machine Mod.# WVSR1060DOWW
The washer will fill up with water but wont aggitate, spin or empty. I can hear a quiet humming like the motor is trying to run.
    Problem Solver:
  • 15 Answers
I love spiderpig
Posted on Jul 13, 2008
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Washer only fills. then completly dead.(timer still advance)
is there any humming coming from under or front of your washer? whirlpool built machines for about 10 years now are "direct drive" ...the motor has a plastic coupling held in place by a rubberish plastic donut type of thing, its an inexpensive fix and there are videos on youtube on how its repaired..its under 10 bucks and usually cures any lack of agitation/ spinning ...i had a roper by whirlpool and once i replaced it from a parts machine i salvaged it was fine.. so check you motor coupler/ coupling and that maybe your answer, if not there is a set of wires and a cut off in back of the motor to prevent overheating, which may have tripped..also a good point to check.. good luck
Apr 30, 2009 | Amana NTW5100TQ Top Load Washer
GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Mar 05, 2009 | GE WJSR1070A Top Load Washer
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
Washer wont aggitate or spin
I think this is the direct drive model, no belt. There is a coupling between the motor and transmission that needs to be replaced. This is a common problem with that type washer.
Dec 21, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
I Have the same problem! Please Help!
Try tipping the washer over forward and look to see if the belt is still in place. If so, make sure it is tight. Have you tried setting the control knob on the control panel ahead a click at a time manually?
Jul 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSQ9549lW0
sounds like something is stuck in the water pump. look under the machine and you will see the water pump front and center of machine.
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
246 people viewed this question
Dan Webster
Dan Webster
Sal De
