Kenmore Oasis he top loader
Our washer has the same problem as others I have seen on this site. It comes on by itself with the lid open, and the end of cycle signal WON'T STOP!!! I can probably replace the board or whatever needs to be replaced myself. Can you tell me were to get the parts? Model #11027092602, Serial #CT4070548.
Thank you,
Jason
  • 5,911 Answers
Searspartsdirect.com is a reliable source for parts for this model washer. Just type in your model number and follow the links on the next page. This site also offers excellent illustrations to aid in part location and assembly. Some other sites you may want to try are repairclinic.com, pcappliancerepair.com and partstore.com for comparative pricing. I hope this helps you.
Posted on Jun 28, 2008
My kenmore elite oasis waher is giving me a lid open fault, but the lid is closed. how do i clear this fault?
the lid switch under the lid is bad and doesnt close its contacts even with the lid down,replace it
Aug 22, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
How to remove casing from kenmore elite top loader screws are in the rear of washer
Here's a link to a video on opening a Whirlpool Cabrio which is the same as the Oasis which is just a Sears branded version of the same washer.
http://s160.photobucket.com/albums/t200/Zenzoidman/Washers/?action=view&current=cabrio-fixitnow.flv
Apr 30, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
How to remove top of kenmore oasis washer to replace lid lock mechanism
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore elite top loader
Call or email the consumer feedback or make a complaint to Sears. I had a similar prob. Sears ending up replacing rhe washer and paying for rental. Took up to 3-6 months, calling and writing complaint letters.
Jun 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Oasis HE 27082 and the lid lock bolt broke. How can I replace it?
5
6
7
You can access the lid switch at this point.
Mar 22, 2009 | Kenmore Washing Machines
Raise top of machine
My appologies, this is my first day on this site. I was answering for a Oasis machine and the profile is now coming up Kenmore top loader. For the Kenmore top loader, there are 3 styles. 1 - The most common is as you look at the back of the console (where all of the knobs and dials are) there are 2 phillips screws where the console meets the top of the washer. If these screws are not present.... 2- check to see if there are two plastic pieces on either end of the console. Remove the plastic covers and there will be phillips screws underneath them. If neither is present.... 3- use a putty knife where the console meets the top of the washer and press. Once you have the screws/ clips removed pull the console towards you and rotate it up. You will now see two brass clips under the console. Place a large screw driver and press down where the clip dips inside the washer while pushing forward on the screw driver. Once these clips are out, the top, front and both sides will all tilt forward and can be set to the side as one unit. Now you can access everything underneath the top of the washer.
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
No display on Kenmore Oasis
there should be a repair manual inside the machine. If you use a screw driver in the front to open the top of the machine the manual should be on the inside of the front panel.
Oct 13, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis - Lid Locked Shut and No Power
take your outlet pipe and place into a bucket so that it is low to the ground if water comes out then it could be that your pump is faulty when the water has all drained away the pressure switch will reset itself and the lid will now open if no water comes out un-clamp your outlet pipe from your pump if then water comes out then your pipe will be blocked m8
Aug 14, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Apr 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
