Question about Canon Office Equipment & Supplies
My Canon i850 will not print. The green light is on but then the orange light flashes several times, then the green comes back on. Nothing I do from the computer seems to affect it in any way, as if they are not speaking to each other. When I plug the cord into another computer, the computer acknowledges new hardware so the cord must be OK. Any ideas???
  • 2 more comments
  • micah1 Jun 27, 2008
    I have re-installed the printer driver, even updated it online, and get the same results from the printer.
    Thank you for that. At the point where I'm supposed to let the green light blink until the head stops moving... the orange light blinks, not the green. If I push resume once and power once to execute a test print, the green light comes on but nothing happens. It is unresponsive to all the other commands, but hey, at least I have a solid green light now. More suggestions needed.
    Sorry, none of that works.... I will try the off an hour suggestion.
    The problem persists unchanged....
  • 58 Answers
Install the printer drive again
Posted on Jun 27, 2008
    Genius:
  • 1,142 Answers
    Brigadier General:
  • 6,966 Answers
Based on your post "...they are not speaking to each other...", the only reason is because the printer is offline. Additionally, the flashing orange light might be indicative of a "Waste Ink Counter". The correct procedure would be to clean or replace before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
The above was originally posted here. Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jun 27, 2008
    Hi again,
    Pls try:
    1. Unplug from the mains for an hour or so;
    2. thereafter while still unplug, try to power ON the printer a few times. The idea is to dissipate whatever stored/residual electricity is inside;
    3. Press simultaneously on "Power" and "Resume", without letting go, ask somebody to plug in the printer to the mains.
    Alternately, you can try:
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    Again, good luck.
  • 796 Answers
Try reinstalling the printer driver again
SOURCE:
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
The orange error light is flashing 5 times in between the green light.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 27, 2010 | Canon BubbleJet i560 InkJet Printer
Canon i850 light is green then flashes orange 7 times then goes green and repeats orange flashing. Printer never gets ready
This is a very bad error. It means that the printhead needs servicing and may need to be repaired. There is no easy fix. Sorry.
Jan 21, 2010 | Canon i850 InkJet Photo Printer
Canon I850 won't print , it has a green light for about 2 seconds then flashes a yellow light for about 6 seconds
Hi there
This is only a try it may do it but I not know,
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i850)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 19, 2010 | Canon i850 InkJet Photo Printer
Light flashing green and yellow will not print
Hi this is only a try it may work
2. Release RESUME
0 presses - green - Test print (or exit service mode on i960)
Jan 14, 2010 | Canon i850 InkJet Photo Printer
Five flashes of orange followed by one green flesh
Jan 02, 2010 | Canon BubbleJet i9950 InkJet Photo Printer
My canon i850 printer head will not move. When I turn the printer on I get a green light followed by 5 amber lights then it alternates 1 long green followed by a short amber,short green, short amber and...
2. Release RESUME
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
Nov 15, 2009 | Canon i850 InkJet Photo Printer
Operator Error Canon i850 printer
2. Release RESUME
Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
Will not print
Remove and re-seat the print head. If need be the print head can be cleaned with hot water. YMMV but I've submerged my i850 print head for minutes at a time. Dry it off, blow it out, and it goes right back to work. Common problem if you're using non-Canon inks.
Nov 07, 2007 | Canon i850 InkJet Photo Printer
1,854 people viewed this question
Clive
Clive
old marine
old marine
Ekse
