Question about HP Office Equipment & Supplies
I HAVE A PAPER JAM AND CAN GET THE REAR DOOR OPEN. WHAT SHOULD DO ?
    Problem Solver:
  • 3 Answers
Try to SLOWLY pull the paper out. Make sure that the unit is off first.
Posted on Jun 27, 2008
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
While printing 2 or 3 lines it shows paper jam message. Can't print even a page!!!
make sure you don't have any small pieces of paper stuck in the printer s.gif s.gif s.gif
Paper jams can be real or false. The unit may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. WARNING: Jammed paper must be removed using the rear access door and the power cord must be disconnected or a carriage jam or mechanical damage may occur. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door c00108288.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  5. From the rear access door opening, remove the jammed paper.
  6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  7. Reinstall the rear access door.
  8. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Jan 10, 2011 | HP Deskjet F4100 All-In-One InkJet Printer
I am having repeated paper jams in the rear door of y HP 4200. It occurs right when the paper hits the rollers to go into the outbin, and the paper stops and jams in the rear door area. I have to open...
It's been a while since I worked on a 4200. Will it print if you keep the back door open?
If yes, does it jam?
If yes, and it doesn't jam, replace the paper delivery assembly(RM1-0026-040CN)
Dec 23, 2010 | HP LaserJet 4200 Printer
My psc 1100 series paper jam. How i can fix
Hi
You need to switch off and unplug the printer. Now open the rear access door by pressing in on the left side of the access door and then pulling it toward you. Now check for any paper jams. From the rear access door opening, gently pull any jammed paper out.
Note-- All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems.
Reattach the rear access door by inserting the two pins on the right of the door into the holes for them, and then pressing in gently but firmly on the left side.
Daniel Scott
Jun 10, 2010 | HP Office Equipment & Supplies
Says Paper Jam But No Paper In It
Hi
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door bd842f6.jpg
  5. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  6. From the rear access door opening, remove the jammed paper.
  7. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  8. Reinstall the rear access door.
  9. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • When loading paper in to the paper tray, push it in until it meets first resistance. Do not continue pushing the paper in. If the paper is pushed too far in, more than one page is picked and paper jams result. This is the most common cause of paper jams with the HP Officejet 410 series.
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once, replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months - one year, clean the paper feed rollers with a rag slightly dampened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | HP Officejet 4110 All-In-One InkJet...
HP ALL IN ONE PRINTER
Follow these steps to clear paper jam
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
Jun 19, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Paper jam
hi,
try this....
> unplug power chord
> remove the paper jammed
> close the rear access door
> plug the power chord
> try to copy
thanks and regards
agnel
Mar 17, 2008 | Office Equipment & Supplies
Paper jam. we removed the major portion of it. bit of paper is inside. we can't find out that. display shows 13.20.00. we removed front and back except toner catridge. what we have to do.
Try this linke below.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=411171&prodTypeId=18972&prodSeriesId=411171&objectID=c00642524
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Sep 27, 2007 | HP LaserJet 3550 Printer
46 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
