Question about Asrock 845GV (P4I45GV) Motherboard
MoBo turns off after booting
Sir I have 845GVSBA Mobo which turn off after booting.
Tried changing Power Supply & RAM.
Any Solution.
Please Help
  • Roberta Smith
    Roberta Smith May 11, 2010
    How far into the boot cycle do you get before it reboots ?
    Robert
Hey, this victor from kenya. Have you confirmed that the heatsink n coler fan is firmly attached to the motherboard? suc error is usually as aresult of non efficient cooing systems.
Also reapply the cooling compound. Use methylated spirit to clear tha old application on the surface of your processor.
If this 2 fail,confirm that you are using a compartible processor to the asrock motherboard.
Posted on Jan 14, 2009
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
PC will not power up. No fans, lights, anything.
Have you tried a different power cord? (longshot, I know, but it is one of the variables that you don't mention)
Have you tried a different A/C outlet?
Dec 22, 2009 | Computers & Internet
Newly built system will not power up!
It seems like you have bad MOBO. I recently ordered all the stuff to build 2 new systems. Built the first one, no power, just like yours. Moved everything to the 2nd MOBO, everything worked. I did a RMA on the DOA MOBO. Got the new one and it fired right up. Sometimes you just get bad stuff.
Please don't forget to rate this solution.
Jun 09, 2009 | Gigabyte GA-8SQ800 Motherboard
Troubleshooting no screen output, please help
sounds like your system is not booting, that may be, obiusly you just have power but that's it...no boot routine. hope somebody else could help on "how to make sure your system can boot again, then the rest.
Dec 23, 2008 | ASUS A8N-SLI Motherboard
No signal
try taking out a gig of ram and then start computer.
Jul 03, 2008 | ASUS P5N-E SLI Motherboard
My Asus mobo P5ld2 cant turn on
Did you try to unplug all AC Power; remove internal surface battery; and then jumper the 'reset' pins from 1-2 to 2-3 ? Leave in this state for about 5 minutes- then replace battery; re-jumper back to pins 1-2- replace AC power cord. Sometimes wiping out the BIOS setup information and restarting/re-setting it up will do the trick!
Apr 12, 2008 | ASUS P5LD2-VM Motherboard
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Presario SR1030AN Turning on but not booting or POST or no any beep at all.
Have you tried switching the power supply out with one that is known good?
Nov 26, 2007 | ASUS A7V8X Motherboard
CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Apr 07, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
P4M80-M4 not powering up
You may have the power and reset connectors on the right terminals, but they may need turning around, normal rule of thumb is if the markings on the connectors are on the outside, then turn them to face inwards.
Mar 28, 2007 | Biostar P4M80-M4 Motherboard
Asrock 845GV (P4I45GV) Motherboard Logo
61 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
