Question about Maytag PYE4558A Electric Dryer
Maytag PYE4558AYW Dryer does not power up at all. Checked power to two terminals on timer and have it there. Does this mean the timer is bad? Someone suggested the thermal fuse. Is this fuse located right where the heating element plugs in and should I have power to at least one side even if it is bad?
  • 2 more comments
  • Anonymous Sep 29, 2008
    Power to dryer, but dryer not running. Found the F1 fuse to be bad. Located under dryer element connections
  • bailey05ice Oct 01, 2008
    Dried a load of clothes, put the next load in and nothing.
    No light, won't start etc.
    Checked the breaker and all was good.
    I read about thermal fuses.
    Does this dryer even have a thermal fuse?
    From the diagrams I found, I don't see one.
    Also, how can I tell if the dryer switch is bad?
  • wmmbwilson Oct 31, 2008
    The same thing happened to me last night.
  • pshreves May 11, 2010
    what are some other problem solving tests I can do to check what is wrong with my dryer Model# PYE4558AYW
    The light does not work nor does the dryer but the timer does work
I bought the thermal fuse kit for this dryer (2 THERMAL FUSES)and replaced both of them. It came with an extra fuse for a gas dryer. It now works fine. Lift the top open. One is toward the rear of the dryer, the other is below the heating element as the other solution said.
Posted on Jan 09, 2009
  • big_will_63 Jan 03, 2014
    A reason that these thermal fuses went bad was because lint had built up in the airway of the dryer after the lint filter. I took the whole front of the dryer off and cleaned the airway to the blower. It was packed full of lint that had accumulated over 10 years.
  • big_will_63 Jan 04, 2014
    When the larger thermal fuse towards the rear of the dryer fails, the heat stops working. When the smaller thermal fuse near the heating element fails, the dryer stops working completely.
  • 525 Answers
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If this doesn't help, post me back and I will do some more research to help resolve your issue.
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 27, 2008
What year is my dryer?model# pye4558ayw. serial# 11311532ax. MAYTAG DRYER
Posted on Jan 20, 2010
  • big_will_63 Feb 18, 2014
    I have the same dryer (PYE4558AYW). Bought it new in 2002.
Troubleshooting m460g timer
you should have power across the two wires to the timer while it is running . Power needs to be on the timer for it to work. One wire should be low ohms to the ground or metal surface and the other wire should be the power wire to the timer motor. if no power on the other wire to timer follow it back and you may find an open in a door switch or temp switch. good luck
Nov 04, 2013 | Maytag Dishwashers
Maytag dryer PYE4558AYW coils heat up then go out.
Sounds like the "cycling thermostat" is bad. Check it for continuity. Here is the part to order in case it is bad.
Nov 10, 2012 | Dryers
I have a Maytag electric dryer, m/n LDE9206ADE. It has no heat, but heater element has continuity. What do I check next? Thanks.
Check the limits on the heater chamber for continuity. If all are fine and the power going into the dryer is fine then the timer is suspect. Find the ower wire from timer to element and check for continuity between that terminal of the timer and all other terminals of the timer while roating the timer to various positions.
If that meter cannot get a read then your timer has a bad terminal(burnt contact)
Mar 05, 2011 | Maytag Dryers
Maytag Dryer DE210 wont start
This fuse is often mounted within the exhaust duct in the back panel. It is about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced.
Good Luck and have a nice day.
Jul 02, 2010 | Maytag Dryers
Dryer won't start, checked thermal fuses and start switch.
It sounds like you have been through most of the areas too look.
One thing to make sure of is that you have a full 240 volts. An electric dryer can measure 120 volts. from L1 to common and 120 volts from L2 to common but you also need to make sure you have 240 volts from L1 to L2 on the meter, one leg of the breaker or one of the two fuses could be blown.
If this is alright you only have a couple components left. The timer contacts and the drive motor. Either of these could be causing the issue.
To check the motor with the power disconnected check for continuity between switch terminal 5 and the Green(black) wire on the motor. If you have no continuity the motor is bad. Check for continuity between the terminal 6 and the yellow wire on the motor, if you have no continuity there the motor is bad. Check for continuity between terminal 1 and 2 on the motor if you you do not have continuity the motor is bad.
The timer should have continuity between the Yellow and Grey wire terminals for the motor to start.
I hope this helps
Apr 23, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Our Maytag Intellidry PYE4558AYW dryer will not turn on
Check the door interlock switch. If it is defective, the machine will not start. If no help, then there may be trouble in the control panel.
Jan 02, 2010 | Maytag PYE2300AY Electric Dryer
Does anyone know where the trermal fuse is located on a maytag PYE4558ayw dryer
yes if you pop the top, the thermol fuse is on the side of the is small and has two white wires too it.your dryer would be dead if it is open.also i recomend you cleaning the filter housing and your home ducting if that fuse is open[bad] God bless i'll be there if you need more help,by way of email tom
Jan 30, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE4558A Electric Dryer Logo
1,181 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
