Question about Juki TL-98Q
Loose stitching underneath. HOW CAN I FIX!!!!
When using machine, there seems to be loose stitching with BIG looping underneith. Have tried thread tension and tighting and loosening. Does alright with straight stitching, but freehand stitching causes problems. Please help!!!. Thanks My machine is throwing loose stitches on the bottom from the bobin side with a straight stitch. I have re-threaded, replaced needle, and cleaned bobbin area. My problem started when a needle broke.
Everything looks fine, but I cannot resolve problem. Please help.
  • Anonymous Sep 10, 2008
    I am having the same problem with my Juki TL-98Q regarding loose stitching from underneath. When I first noticed the problem I called the person from whom I purchased the machine. The technician in their shop walked me through rethreading the machine, readjusting the tension, and cleaning and oiling the hook area of the machine. At the time, it appeared to help the situation. Since the problem appeared to be solved, I put another quilt on the frame and began quilting. About halfway through the project, once again the stitching from the bottom side of the quilt resulted in large loops. I read the solution offered to dwattstgtel, but I do not have any rough spots on the hook. Please help. This is the second quilt that has been messed up because of this problem, and I am ready to get rid of this machine.
  • Anonymous Mar 19, 2014
    Pfaff 6122 bobbin stitch loose, makes straight line
  • 323 Answers
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Posted on Jun 27, 2008
Top stitch is fine bottom is loose. Have tried adjusting tension but not working. If I get tension too tight breaks thread so I gradually change tension to no avail. Please help
Check your stitch sample. The loose stitches under the fabric--are they actually top thread???? Usually,stitch problems under the fabric is a result of a top thread problem. In this case, it could be bird nesting.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot.
Rethread from the beginning.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 21, 2017 | Sewing Machines
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Dec 22, 2016 | Singer Sewing Machines
Phaff 1472 stitches are bunching up underneath
That is thread nesting or bird nesting. Could be the result of several things, but main reasons are upper tension too loose and the thread not being completely seated in the tension disk.
Nov 17, 2016 | PfaFF Sewing Machines
My Bernina Artista 185 has been looping the top thread on the underneath side. Is this a tension problem? No amount of adjustment seems to correct it. What can I do to correct the looping problem?
It is a tension problem. My advice is always to double check in the manual that you are threading correctly. With loops underneath, your tension is too loose, or the bobbin is not seated properly.
Nov 18, 2015 | Bernina Sewing Machines
Singer 2517c. When sewing, the bottom stitch is using to much thread, excessive amounts & the stitch isn't tight. I've tried all settings & have used a new bobbin. I'm at a loss......
Your description isn't very clear. When you say the "bottom stitch is using too much thread" Do you mean you see lots of loopy threads on top of the seam? Or do you mean you see loops on the bottom under the fabric? If your loops on the bottom, that means the top tension is too loose, you've not remembered to put the presser foot down, you have not threaded the top thread properly... Start by rethreading carefully with the presser foot UP. Then do a test stitch, remembering to put the presser foot down. If you still get loops underneath... tighten the tension.
If your loops are on the top of the fabric. loosen the top tension... then do a test seam... and if you still have loops loosen again and repeat. If you start to see loops on the bottom... tighten the tension a bit.
Good luck
Dec 30, 2012 | Sewing Machines
Bought used--trying it out---top stitching is
Check to make sure that the thread running between the tension disks. A quick check is to lower the presser foot and then pull on the top thread. If you do not feel any tension, then it may not be ran in between the disks. Also, check to see if your bobbin is inserted correctly going counter-clockwise. This can cause the "loose" loops and thread jams in the bobbin casing.
Feb 10, 2010 | Singer 5050 Mechanical Sewing Machine
Sir I am owning a Janome Memory Craft 10001 but recently it's not working properly in ordinary sewing mode the top side of the fabric the stitch looks okay but underneath it is loose and while embroidering...
Usually If the underneath is loose it is the top tension that is the problem. If it is the top stitching that is loose it is the bottom tension. Hope this helps.
Jan 24, 2010 | Sewing Machines
I have the Brother ls2125i and LOVE the machine...in the middle of sewing, it started making very big loops on the bottom stitch and they do not catch the thread from the needle. Is it the tension?...
Here are some things to try:
Big loops are actually easier to solve usually. 1st know this: Loops on bottom means the top is too loose or the bottom is too tight. With loops that big its probably the top is too loose. 1st look in tension disks, there is likely a chunk of thread in there. A toothpick is handy to dig it out (the flat kind) 2nd make sure that the thread is getting between the disks when threaded. 3rd Make sure the thread is in the take up lever (the thing that moves up and down in front and not the needle bar or any part of the needle bar.) If neither, then the bobbin case could have a burr on it and the thread is hanging on that burr. Also the bobbin case may be in wrong. I hope this helps
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no matter how much thread you pull, your thread is good. If that your machine passes that test, we can go to step 2. If not, try different spool of thread, do the same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Kent
Mar 22, 2009 | Brother LS-2125 Mechanical Sewing Machine
No bobbin tension
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Bottom thread is very very loose during stitching, looped up
Looping on bottom:
Great description, that helps a lot. Big loops are actually easier to solve usually. 1st know this: Loops on bottom means the top is too loose or the bottom is too tight. With loops that big its probably the top is too loose. 1st look in tension disks, there is likely a chunk of thread in there. A toothpick is handy to dig it out (the flat kind) 2nd make sure that the thread is getting between the disks when threaded. 3rd Make sure the thread is in the take up lever (the thing that moves up and down in front and not the needle bar or any part of the needle bar.) If neither, then the bobbin case could have a burr on it and the thread is hanging on that burr. Also the bobbin case may be in wrong. I hope this helps
Kent581
Mar 03, 2009 | Husqvarna Viking 1
Juki TL-98Q Logo
556 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
