Question about Broan-NuTone Broan Range Hood Accessory
Damper need for Broan Range Hood
I am venting the hood starting with 7" round ducting and converting to 31/4 x 10" rectangular. I have to start vertically and then turn 90 degrees to wall vent. Directions for a 7" round ducted discharge say to install 7" round damper,(not included in packaging). Is this needed if the Broan wall cap has a damper? Also what is the best location for the round damper if installed? Note that the Lowes I purchased where I purchased the hood did not carry the needed damper accessory.
  • Anonymous May 10, 2009
    Same here, Broan dissapointed by not including the 7" damper!!
I called tech support at Broan and was told they recommend two dampers in cold climates ...one at in the wall cap and one on the unit. They make the damper,
(#BP87-7"), that attaches to the round duct plate that comes with the hood. Strangely the unit does not include a round damper and the seller LOWES did not have it, also checked Home Depot,.
The Tech said they can't get stores to stock it. I checked at a local supplier of all kinds of plumbing, heating, and cooling supplies and they only had basic 7" dampers which, I was told would probably be too heavy, and be manual. I ordered it through Amazon/True Value ($11.56 w/ shipping, shipping more than cost of damper). Tech indicated that the 2nd (unit damper) is optional and may not be needed if in a warm climate. I would suggest that Broan include the $5.00 item in their unit or at least sellers stock it.
Posted on Jun 28, 2008
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
In winter, cold air blows back down and out through the fan.
Either a backdraft damper was never installed in the ductwork or the damper is stuck open...
Has it always been this way?? If so then the damper probably was never installed and you will need to have one installed to stop the air...
If it was good at the beginning and now is not then the damper is stuck open...you will need to find it and then get it working agian...
The dampers often are right at the outlet of the hood...if you take down the hood it should be right there...
heatman101
Feb 11, 2011 | Broan-NuTone Best By Broan EB12 External...
Offset venting of new microwave/range hood to old fixed venting
You might try your local furnace or heating shop as they can usually custom make ducting and may be able to do this for you, but I am sure it will cost. I have had similar problems and usually a good sheet metal man can help.
Oct 08, 2009 | Kitchen Ranges
Broan range vent fan not working; motor humming but will not turn, light works fine, not the fuse.
The motors will go bad from time to time. I would check Broan's web site
www.broan.com
or fill out this form
http://www.centralvacuumstores.com/fan_help.php
Sep 12, 2009 | Broan-NuTone Broan Range Hood Accessory
Extraction ducting too long!!
To get the correct dimension, you could make up a template out of thin carboard to do your testing before you cut the metallic duct.
You will need to match the area of square inches of the duct, no matter the shape. If it's round the formula is (pi (3.1416) x radius squared). If it's square or rectangular, it's L x W in inches. Your local home improvement store (if there is one) should stock various adapters and metallic round duct.
Note that since this is being used in a kitchen, the duct should be metal and it should vent to the outside unless it is a recycle hood.
Let us know if that helps...if not we'll try again!
Jun 06, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Range hood installation
you can reseal the hole with aluminium tape
you can use screws with metal flat washer that has a rubber backing
May 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Range vent damper noise
Check to make sure that the installer completely untaped the damper when he installed it. It needs to be able to move freely.
Apr 04, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
7" damper
The damper you are looking for is Broan part number 97. It is available online.
Jan 17, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
How to find rectangular to round transition adaptor
They used to sell them at sears. Its a common duct item for vents. Try home Depot.
Jan 13, 2009 | Samsung SMH7178STD Microwave Oven
Jenn-Air Downdraft ducting roof Rack w/flapper
go to www.luxurymetals.com
there are many good high quality vents on the site
Oct 08, 2008 | Jenn-Air HV363 Kitchen Hood
Broan-NuTone Broan Range Hood Accessory Logo
1,831 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
