Question about Canon imageRUNNER C3220 Color Copier
Error code E000584-0001
I'm getting the error code E000584-0001, I've tried shutting the machine down and restarting it a few times, waiting ever increasing amounts of time between shutting down and starting up, and I continue to get this error. Any idea what this error code means (or even better, if there is a list of these codes online somewhere, so that I can diagnose these problems a little more efficiently?)
  • Canon Expert
  • 287 Answers
Hello Wyatt,
It took me a moment or two to find the explanation to this error. It appears you have a saddle stitch finisher as that distinguishes the error code. Canon does not lump all error codes together (concerning all available peripherals) in one spot. In brief, the code means that the second feed motor (which will initialize at start up/and only pertains to the saddle stich feature) was not recognized as acting properly. When the machine starts up it checks a tremendous amount of inputs and outputs and the second feed motor (m8) is one of those. The controller pcb of the finisher told the main controller of the copier that "m8" did not perform it's function. To simplify the diagnostics, either the motor did nut turn, or the shutter it drives is bound, or the finisher pcb has lost its mind, or best of all the copier is misinterpretting the data from the finisher pcb. I know this does not fix your problem, but at least you know where to look and what to look for. And if "copier dude" (which I am one) says you need a new SPLEEN you can tell him to go to hell !!! I wish I could be of more help.....and I can be for a nominal fee.......( plane tickets, hotel,mixed drinks) lol
Posted on Jun 28, 2008
We had this code and it turned out that the nearby garbage can was sitting under the trays and preventing it going all the way down into position. We moved the can and it stopped this error.
Posted on Aug 29, 2008
Sharp Model MXB401 Error L4-16 what is it and how do i fix it
Hello Joanne,
The error that you are receiving is due to worn gears going to the fuser assembly that need to be replaced!
The repair thread can be read at either link below:
Thread MX B401 L4 16 error
sharp mfp mx b401 error code c4 16
Good Luck!
Rich Lilja
Feb 24, 2015 | Sharp Office Equipment & Supplies
What is error code E57?
E57 Checksum failure Software error occurs - checksum failure. Non-recoverable error. Main control board must be replaced.
Nov 07, 2014 | Washing Machines
Konica minolta bizhub c253,how to reset transferbelt by using fusser
There are two ways to reset an error code:
  • 1. Open the front cover, wait for a few seconds and then close it. If the error is still there try the second method.
  • 2. Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed; keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below.Restart it normally and it should work. If the error is still there, try to follow the steps provided in the solution found based on your error code.
Aug 21, 2014 | Office Equipment & Supplies
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
Hello, I have a laptop Dell Inspiron 1501. A two days ago I reinstalled Windows Vista, because I've had some problems wih my internet connection and some other. So I installed it and everything is ok,...
Hi!
It is not yet the end for your machine. The error codes refers to a faulty hard drive. You'll need a new hard drive for replacement and that will fix the problem.
Should you have any other questions just leave a message.
All the best!
Musicaddict
Sep 15, 2010 | Computers & Internet
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I get a u61 error code. Manual says nothing wrong with unit and will reset itself-has been 2 days
Shut down power, unplug from wall power socket, wait a few minutes then plug in and try again. This is the reset process, to load codes into drams properly when the machine is no longer in standby mode.
Jun 27, 2010 | Panasonic DMR-ES35VS
Error code is 0180
mr rupabai your problem is in the magenta starter try to intialiaze it again by pressing " 28 at the same time
copier
function
install
int m press it and wait a few minutes if an error occured after intializing change the magenta starter and intialized again
Mar 21, 2008 | Canon CLC 1120 Color Copier
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Canon imageRUNNER C3220 Color Copier Logo
1,346 people viewed this question
old marine
old marine
