Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
New problem I went to try what you said and now the computer won't even turn on. Could all this be due to a bad power supply?
I FOUND THIS COMPUTER IN THE TRASH. POWER PLUG POWER SUPPLY TO MOTHER BOARD BAD CONNECTION GREEN LIGHT ON BACK OF POWER SUPPLY & GREEN LIGHT ON FRONT WAS BLINKING.PLUGED IN & UNPLUGED TILL THE LIGHT ON THE POWER SUPPLY STAYED GREEN (SOMETIMES THIS TAKES A MIN). COMPUTER IS WORKING FOR TWO WEEKS NOW. NO PROBLEM YET. IF I MOVE THE COMPUTER IT WILL DO IT AGAIN. AT THE TIME THIS COMPUTER DIDN'T MATTER TO ME. MAY BE MOTHERBOARD SHORT. TRY AT ON RISK.
Posted on Sep 05, 2008
My Sound card is uninstall. tall me how i re install it.(i don't have driver c/d. its missing.)my pc model no is (Compaq Business Audio driver for window 98 In Intel(R) 82810.).my email id is www.jit.sengupta@rediffmail.com
Posted on Jul 29, 2008
HP Pavillion a1514n Won't Turn On
Yes even with the green light on it could still be the power supply. Have you pulled the power, opened the case, and pulled the BOIS battery? Could be the BOIS needs to be reset. You might also pull all the memory chips, turn it on and see if you get a beep code. I have had that happen in the past. Then I would replace the power supply (if you have an old one laying around use it to test, with just the MOBO plugged in). If the power supply fails, that leaves only the mother board as the issue.
Good luck, I hope one of these suggestions works for you.
Jun 29, 2012 | HP Computers & Internet
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
Blew a breaker and now my computor won.t turn on
Try this, unplug the computer, hold in the power button for 30 seconds or so (this will discharge the capasitors). Now plug the computer back in and try to turn it on. If you still get nothing, try a different surge suppessor. If you still get nothing, try a different outlet. If all of this fails, you most likely have a bad power supply. You will have to open the computer, uplug the power supply from the motherboard, hard drives, DVD drives, ect. Play close attention to what plug goes were. Remove the screws holding the power supply in, and remove it from the computer. You can take this old power supply to about any computer store and find a replacement. Put in the new power supply, plug everything back in. Hopefully the computer will now boot up and run. If not you could have a bad motherboard.
I hope this helps
Jun 20, 2012 | Lenovo Computers & Internet
My computer went blank when turning it on
1) Computer isn't working, due to the Processor isn't working, due to a bad Power Supply.
Weak voltage power rail.
Enough power perhaps to light LED lights, and maybe spin fans, but not enough power to turn the Processor on.
Computer Power Supply's are rated in Wattage.
Volts times Amperes = Watts.
(Average computer power supply in a fairly new computer, is rated at around 300 Watts)
A) ALL of the LED lights combined, use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts.
C) A typical Processor may use 51 to 125 Watts.
Depends on what Processor it is.
Power Supply with a weak voltage power rail, can have enough power to light LED lights, spin fans, but not enough to turn the Processor on.
Solution?
Test the voltages of the Power Supply,
Or, use a KNOWN to be good Power Supply, that has the correct amount of power cables, the right kind of power cables, the correct size, and shape of the case, and enough Wattage, for a test unit..
A bad Power Supply is one of the leading causes of computer failure.
Sep 19, 2010 | Computers & Internet
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Monitor won't stay on
More likely to have problem in the power supply due to bad caps, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 01, 2010 | Envision EN9410 19" Flat Panel LCD Monitor
Deep freeze computer inresponsive
it sounds like your computer power supply went bad.
go to your local computer store and buy a power supply, install it and you should be up and running.
that is if you didn't fry everything from running it without the proper cooling.
make sure that you have proper cooling fans in your computer, a fan outside will not do it.
It sounds like your power supply fan stopped working and it just got to hot and died
May 24, 2009 | E-Machines eMachines Desktop PC
Unable to reboot
Sounds to me like you have a bad or dying power supply. Try finding a friend with a working power supply and hook it up to your computer, if the problem ceases, then go get yourself a new power supply. If the problem persists, it may be an issue with cables or the fuse, maybe even a bad motherboard.
Mar 12, 2009 | Computers & Internet
No power
Had the same problem after the electric went out due to a storm. When the electric came back on the computer wouldn't turn on. There was a light flashing on the Power Supply and on the mother board. I disconnected the large white Power connector from the motherboard, waited 15 seconds and plugged the connector back in, the light came on solid, press the on/off switch and the computer booted up and continued to work fine.
Jun 18, 2008 | Sony VAIO VGC-RB52 PC Desktop
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
128 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
