Hotpoint Aqualtis Error code F11
Hi I have an error code F11 on my aqaltis wasshing machine., I found out that i needed a new drain pump as the old one had burnt out, too many tries trying to drain it when the filter was blocked i presume. The new pump is on but the same error code comes up. I have checked the hoses unblocked and that the drain pump is correctly fitted . I have also checked that the electrical connector is pushed in properly.
Still no joy
  • Anonymous Mar 23, 2014
    pump drain problem
Please could someone help as i have the exact same problem with my aqualtis zqxgf149,exactly as above,fitted new pump myself and its now emptying the water but wont spin and in wash cycle f11 comes back up
Posted on Jan 03, 2011
Hi I have a hotpoint ultima it is showing f11 could you tell me what it means Thanks
F11 - No pump connection.The drain pump is either blocked or drain pump is loose or drain pump hoses are loose .Or the drain pump connections are faulty. The error f-11 is related to drain pump and its connections,. ----------- You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint wt640 will not empty and has an f11 code
Hi
Error F11 means that F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked. This may also have happenned if the washer is not draining. It may have happenned due to drain pump is not working. Try and check the drain pump, if the connections to the pump are fine. Please post back for further assistance.
Daniel
Jul 25, 2010 | Hotpoint Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Hotpoint wt741 f11 what does this mean
Hotpoint Error Codes.
Hotpoint washing machines are among the most common found in the Uk and like any mechanical device they will occasionally breakdown or develop a fault and need repairs.
Being a very popular make means that most parts supplier will keep there parts in stock and because so many suppliers keep Hotpoint parts stock this also drives competition hence driving down the price of parts if you should ever need them
One problem many people including some engineers face when faced with a faulty Hotpoint washer is knowing what the error code mean, so here are a list of error codes and there meanings for Hotpoint washing machines
These error codes can some times have a E in front of the number and not a F as shown here, but the meaning of the code is still the same
# F11 - This means there is No hot fill.The ambient temperature is probably below freezing perhaps due to the plumbing becoming frozen. Also verify that the taps are on or if the drain hoses are kinked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 26, 2008 | Washing Machines
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Hotpoint wd640 f-05 and f-11 error codes washer does not empty
f05 say pump blocked or pressure switch fault. whereas f11 say pump cannot be activated... so either an open circuit pump or fauty pcb..
Oct 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
1,241 people viewed this question
Top Washing Machines Experts
