Question about Haier HDN655E Dehumidifier
No Power The unit control panel is dead...nothing. May be over a year since I purchsaed so the cost and time hassle my be too much. Any suggestions?
  • bauerms Jun 28, 2008
    Check the fuse on the inside of the unit (wrapped in a blue rubber protection)...good luck in finding a replacement (difficult). does anyone know where to find a replacement fuse?
  • Anonymous Jul 16, 2008
    Excellent advise. Tore my unit apart and found the "blue plastic cap" hidden on the circuit board. Fuse blwon. replaced with one fro mradio Shak and Wham - unit operating back to normal. Thanks!
I had same problem and thanks to your post I was able to remove the housing screws and locate the fuse hidden under the "blue" plastic cap - so it would easily be missed by someone not in the "know".
I didn't have the exact fuse so I replaced it with a slightly larger glass tube fuse (same current just physically bigger. YOu could go to Radio Shak and get the fuse (just tke the old one with you to get an exact replacement) but I went with the one I had on hand.
Placed the unit back together in 5 minutes and wham - she works good as new.
Thanks for the tip on the fuse - I would have missed that one only because iut was cleaverly hidden by the blue plastic cap.
Saved $200 for buying another de-humidifier. Sweet.
Posted on Jul 16, 2008
You can also find the part at www.partsquik.com. Order part# AC-3050-02.
Posted on Jun 28, 2008
Found the fuse at this website www.tiewraps.com ORder the AG-12
EC appears and it doesn't draw water
I contacted CE North America customer service regarding this issue for same unit. They suggested disconnecting for 10 minutes, then reconnecting, turning unit on, and changing settings and run fan on HIGH or TURBO until the EC code goes away. This didn't help with my unit. If this doesn't work, there is no repair provided. Customer Service recommended returning unit to purchase location if under warranty (1 year), however a copy of the original purchase receipt is required. Suggest a call to Customer Service Center at 866-915-1212.
Jun 01, 2014 | KUL 30 Pint Dehumidifier
My dehumidifier is (6) years old. Only used (4) months a year in this climate. Plugged it in this year for the first time and the fan is blowing on high without the power button on. Fan speed control with...
My guess is something got into the controls and has shorted the power to the fan. Take panels off of the unit and vacuum, and wipe or brush, with soft brush, as much as you can. Do not use any liquids in cleaning. Hope this works for you.
Jun 01, 2011 | Maytag M7DH65B2A Dehumidifier
Purchased june 2004- fan runs and compressor runs but does not sound to be working only idleing lights around the instruments are lighting but no numbers appear in the console dash Any...
Laverne, most of the time repairing a 7 year old dehumidifier is as costly (parts - if you can find them & labor) as buying a new one. As far as the problem you're having is concerned, it sounds like one of the sensors has failed. You may try the following, t see if the unit will reset itself.
Turn the Master ON/OFF Switch to OFF. Unplug the unit and leave it unplugged for 12 - 15 minutes. Plug the unit back in, turn On the Master On/OFF Switch and set the controls as you normally would. Hopefully, that 12 - 15 minute timeout, allowed the electronics to reset themselves and the unit will function as it should.
Hope it works for you.
Apr 19, 2011 | Danby DDR600R Silhouette Dehumidifier
Dehumidifier' problem
1. Very few companies manufacture their own dehumidifiers. 2. Due to cost concerns, the coils are made of steel (not something like stainless steel) and will rust / corode, causing refrigerant leakage, often times after only a couple of seasons. 3. Maytag is not the Maytag of 15 years ago. They cheapend their product to lower cost, looking for increased sales, and have been bought out by Whirlpool.
May 27, 2010 | Maytag M7DH45B2A Dehumidifier
My Comfort-Aire BHD-501-B is running. However, none of the control panel buttons work. I cannot turn it off with the on/off button. I cannot change the humidity set point using the up or down arrows. I...
I don't think it's a thermistor problem, as previous respondents have suggested. I have one of these units. The control panel has been nothing but trouble. The Power button works, but the Fan Speed button is stuck on High. The Humidity Up/Down buttons only work sporadically. Sometimes they work if I keep punching them. There doesn't seem to be any rhyme or reason as to when they work and when they don't. I think they're just cheap parts that have failed prematurely.
May 03, 2010 | Comfort-Aire HD-651 Dehumidifier
Haier HDN305 Dehumidifier
agaver
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks qrx1llb3 for the help!
After carefully removing the plastic covers (yes, u need to remove both, I removed first the back one then the front one by pulling up, then disconnect the cable that joins the panel on the front cover with the electronic board on the upper right area) I found the electronic board with the blown up fuse. My was under a blue plastic cover. I'll try to replace it and see what happens! thanks for the help! :)
Jun 27, 2008 | Haier HDN655E Dehumidifier
Humidity Control
Sounds like the button may be broken. However, it could be a loose wire. Take the front off and see if any of the wires connecting the control panel and the unit are loose or disconnected.
If there is a ribbon cable connecting the control panel, see if any of the contacts are exposed when you disconnect it. If they are, you may be able to use a pencil eraser to clean them off. A service man from Sears did this on the control panel for my ceramic-top stove. He said if that didn't work then I would have to buy new control panels, which were almost the cost of a new stove!
Sep 09, 2007 | Kenmore 54501 Dehumidifier
A7dh65b2a
Normal operation, the unit has sensed icing and is in the defrost mode (compressor off and fan on high). When the ice melts normal operation will resume.
Dec 07, 2006 | Fedders A3DH30B2A Dehumidifier
Haier HDN655E Dehumidifier Logo
193 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Mike Squire
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
