By Mini Me - usenet poster
I have a brand new JVC AV27230 which I'm not sure if there is actually a
problem. There is a low frequency humming noise coming from the speakers.
When the speakers are on mute, the humming noise is noticeable but when the
audio is turned on, it goes away, until there is a pause in the audio. When
I disable the speakers, the noise is gone. My wife don't seem to notice
this...but I do. Is this a problem?
Solution #1
posted on Aug 11, 2005
LiZzIe - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
ken_b:
This might be something simple....... BUT........ since you said your JVC
AV27230 is "brand new" it would be your best decision to take it back where
you purchased it and return it for another one or a different model. It
would not be wise to void the warranty trying to fix this yourself. To
protect your warranty, only a JVC factory authorized shop should be
attempting to fix this.
Best Regards,
Dan Sofie
Electronics Supply & Repair
Best Regards,
Dan Sofie
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
lawyer - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
This sounds like bad main filter capacitors or some bypass capacitors in the
buss in the power supply, or a defective component causing some type of internal
ground loop. It is best to get this attended to before there is an expensive
failure.
Jerry Greenberg GLG Technologies GLG==============================================
WebPage <http://www.zoom-one.com>
Electronics <http://www.zoom-one.com/electr on.htm>
Instruments <http://www.zoom-one.com/glgtec h.htm>
failure.
Suggest a new solution for this problem
Post a New problem for JVC AV-27230 27" TV
Email this problem
Email this problem
Can you Help with these Standard Televisions problems?
JVC AV-27230 27" TV
HP Pavilion laptop battery life
When running on battery power,... Answer This...
Repair Service
Find Standard TV Repairman Near You:
